Multiple setups on one 7i96 board
  • neil52
  • neil52's Avatar Topic Author
  • New Member
  • New Member
10 Aug 2021 21:31 - 10 Aug 2021 21:36 #217426 by neil52
Multiple setups on one 7i96 board was created by neil52
I have a dual purpose homebuilt machine,have always had a router and plasma cutter set up for each on earlier versions . Upgraded to 7i96 board and want to know if this is still possible.or would I need to flash the 7i96 every time I change?
Last edit: 10 Aug 2021 21:36 by neil52. Reason: wrong wording changed setup to versions
10 Aug 2021 21:45 #217427 by rollfree
Replied by rollfree on topic Multiple setups on one 7i96 board
I do not know the exact configuration of your machine. But if you wiring it just a little cleverly, then I think there's no reason to reflash the configuration.
  • neil52
  • New Member
  • New Member
10 Aug 2021 21:52 #217428 by neil52
Replied by neil52 on topic Multiple setups on one 7i96 board
setups basically the same only some i/o pins are used in one but not the other
  • Moderator
  • Moderator
10 Aug 2021 22:07 #217431 by tommylight
Replied by tommylight on topic Multiple setups on one 7i96 board
You just need two different configs, no flashing required.
The following user(s) said Thank You: neil52
11 Aug 2021 11:07 #217518 by rodw
Replied by rodw on topic Multiple setups on one 7i96 board
You might be able to run a single config and use the multispindle feature  with the router on Spindle 3
Se how Plasmac uses the engraver as an example.
11 Aug 2021 17:46 - 11 Aug 2021 17:46 #217566 by PCW
Replied by PCW on topic Multiple setups on one 7i96 board
Note that you can use multiple configurations without reflashing the 7I96
by first flashing the alternate firmware to the fallback location, then you can
switch firmware by selecting the desired firmware via mesaflash:
Choose primary configuration:
mesaflash --device 7i96 --addr 10.10.10.10 --reload
Choose alternate configuration::
mesaflash --device 7i96 --addr 10.10.10.10 --fallback --reload
Last edit: 11 Aug 2021 17:46 by PCW.
16 Aug 2021 23:13 #217921 by andypugh
Replied by andypugh on topic Multiple setups on one 7i96 board
But you probably don't need to change the firmware. If it is all the same machine then just use a number of INI files (one for each machine arrangement) all in the same config folder.
My milling machine can operate as a horizontal mill or a vertical mill. Or a gear hobber, and with 3, 4, or 5 axes. I do this by having several INI files and a selection of shared or unique HAL files for each configuration. They all share the same tool table, but different .var files.
Joint.0 can drive stepgen.5, for example, so it's just a bit of HAL tinkering to swap axis allocations around.
Time to create page: 0.127 seconds
