G96 - S word missing error
5 years 2 months ago #217636 by Diederik
Can someone please advice me? I upgraded my lathe last night, to try out the G71 function.
I first tried the example G71 program, but when you stop it in the middle of the program, then you need to restart linuxcnc to try again.
It gives a error: G7x error: Not monotonic.
I also tried to write my own program, but immediately comes up with the same error.
Does anyone have some examples that's working?
5 years 2 months ago #217684 by Diederik
Okay, I think there might be a problem on 2.9
Today I'm trying to run a part that I did before, No changes to the program, Then when I stop the program while it's busy machining, Then I can't restart it again. Gives me a error Line 0 of my program, no S word given with G96.
Then I have to restart linuxcnc again.
5 years 2 months ago #217694 by BigJohnT
If you think there is a issue the correct place to report that is:
github.com/LinuxCNC/linuxcnc/issues
JT
The following user(s) said Thank You: Diederik
5 years 2 months ago #217723 by EW_CNC
I have been having the same issue of getting the error "S word missing with G96" when reloading a G71 file.
I've been using the workaround of issuing a MDI "G97" as shown in this link. bugs-issues-found-running-a-lathe-in-2-8-0-pre1#102320
If this is a bug one of us should get it reported.
EW
5 years 2 months ago #217738 by Diederik
I Downgraded back to 2.8, and still have the error: S word missing in G96, even in 2.8
So I tried to just get the job finished yesterday, and endured the problem to finish the job,
Thanks @BigJohnT, I will report as instructed.
5 years 2 months ago #217739 by Diederik
Okay, I reported it on Github.
github.com/LinuxCNC/linuxcnc/issues/1232
Thanks everyone>
Time to create page: 0.579 seconds
