stepper motor oscillation
- robertspark
- Thank you received: 216
17 Aug 2021 19:31 - 17 Aug 2021 19:35 #218009
by robertspark
stepper motor oscillation was created by robertspark
never seen this before.....
simple 3 axis stepper motor setup for a mill.
X, y, z + analog vfd
no encoders, glass scales etc.
l was jogging the z axis upwards and when I released the keyboard pgup the z began oscillating back and forth in ever decreasing motion.
first question, how is this possible..... I understand how it could happen with a closed loop arrangement, but this is purely stepper motors, no feedback..... so I would presume linuxcnc would just output step and dir pulses.
it is via a Mesa 7i76E, and the stepper motors are big hefty nema34's, the velocity of the motion was not very fast at all (it was driving a 10mm pitch acme leadscrew)
just never expected to see oscillation without a feedback signal
(I set it up using pncconf and although I've seen the PID values in the hal/ini file, I just left them at default (I think 1000 or 10000 for P, and I and D are zero.... given no feedback signal.... didn't expect any ringing)
Last edit: 17 Aug 2021 19:35 by robertspark.
- Online
- Thank you received: 5321
17 Aug 2021 20:24 - 17 Aug 2021 20:25 #218012
Replied by PCW on topic stepper motor oscillation
The hardware stepgen uses "local" feedback which must be set
up properly for the servo thread rate.
FF1 should be 1
P should be 1/Servo thread period (or 1000 for a 1 ms servo thread)
A P of 1/servo-thread-period means that any errors between the expected
position (from LinuxCNC) and actual position (from the stepgen hardware)
are corrected at the next servo thread.
If the P term is higher than 2/servo-thread-period you will get oscillation
with ever increasing magnitude.
FF1 should be 1
Last edit: 17 Aug 2021 20:25 by PCW.
The following user(s) said Thank You: robertspark
- robertspark
17 Aug 2021 21:16 #218017
by robertspark
Replied by robertspark on topic stepper motor oscillation
thanks as always I'll take a look.
servo thread is 1000, so I think (will check) that p is 1000 as it was default as per pncconf.
the FFx I didn't change (I didn't change any of it really)..... didn't know what the FFx was for
- Online
17 Aug 2021 21:54 #218022
FF1=1 basically sets the stepgen velocity correctly before any feedback
is applied.
I have seen pncconf set wrong P values if you ever changed the servo
period
is applied.
period
Time to create page: 0.172 seconds
