Driller
25 Sep 2010 20:16 #4337
by occesar_0
Hi everybody
I'm doing a driller machine and these are it's main characteristics:
3 axis
3 drillers controlled by pwm mounted in my z axis
Therefore, the three drillers moves at the same time, but with the correct mechanical array, I'm expecting to handle them, one by one when requires, in a independent way.
An example could be this:
I need to drill five surfaces, first three and then the other two, so It would be convenient disable the third drill, there's a way to do that in emc2?
Thanks in advanced
3 axis
Thanks in advanced
25 Sep 2010 20:52 #4338
by BigJohnT
Replied by BigJohnT on topic Re:Driller
You could use a digital output with g code, a user M1nn, a pyVCP button... to name a few. Just depends on how you want to turn it off and on.
27 Sep 2010 14:30 #4366
Replied by andypugh on topic Re:Driller
BigJohnT wrote:
I think perhaps an analogue output would be most appropriate, acting much like spindle speed, and wired the same way.
You might perhaps want to link it via a mux2 in HAL so that it could be turned on and off like the "main" spindle.
So, where normal G-code would have
S300
M3
You might have
M68 E0 Q300
M64 P0
(and M65 P0 to turn it off again)
S300
M3
You might have
M68 E0 Q300
M64 P0
Time to create page: 0.212 seconds
