Problema en puerto paralelo, creo.
- kayovre
19 Aug 2021 22:09 - 19 Aug 2021 22:17 #218182
by kayovre
Problema en puerto paralelo, creo. was created by kayovre
Error al iniciar linuxcnc desde el primer momento, creo que algun problema con el puerto paralelo que no se solucionar pues no tengo ni idea de linux. intentare adjuntar una foto del texto del error y si alguien me puede ayudar se lo agradeceria. Un saludo.
https://ibb.co/8bVBt1n
texto:
LinuxCNC terminated with an error. When. :
please include all the information below in noes
¡Print file information:
ÍRUN_IN_PLACE=no
ILINUXCNC DIR= el UNI A i| | UT
[LINUXCNC BIN DIR=/usr/bin WWW I) i UNI
}LINUXCNC _TCL_DIR=/usr/lib/teltk/Linuxenc CUIT UU l
ILINUXCNC SCRIPT DIR=
TNUXCNC LANG _DIR=/usr/share/Linuxenc/tcl/msgs
| INIVAR=inivar
HAL CMD=hal cmd
LINUXCNC EMCSH=fusr/bin/wish8 5
[LENUXCNC - 2.7.15
¡Machine configuration directory is -¿home/fran/linuxcnc/configs/my-mil1'
¡Machine configuration file is 'my-mill.ini'
|. INTFT E=/home/f rany/Linuxenc/ /configs/my-mill/my-mill.ini
PARAMETER FILE=(inuxenc . var
ASK=ni 1 task
lar UT=
Fting LinuxCic...
[Starting LinuxCNC server program:
i OS, RTAPL,
10 program
Uinuxencsvr
and HAL LIB modules
358
p LinuxQic...
teal Hime 05 modules
nents I
i =] n > , “ “wire A sea > bus)
r/réa me-3.4-9-rtai-686-pae/modules/linuxenc/hal parport.ko: Device or resource busy
li parport failed, returned -1
for more information
lun toading hai
Kernel message information:
cor puset
[ § 999060] Initializing cgroup subsys > sa | 6.3-14) ) £l SMP PREEMPT Debian 3.4.55-4linuxene
L r car £ ubsys Cpu i { riersion 4.6.3 (Veblan 4+.b.3-1% i 2 eE
i §.999900] Initializing cgroup st E echinn 5455.4tinuecnc) () (gee version 4,1
[ 098088] Linux version 3.4-9-rtai-686-pae (Debia
i rovided physical RAM map: Scan aha
\ a = e820 há 6000000000 000000000009e200 a
ee > ss q ) } } ( sserye
[ 6.000800) B10S-e820: 0000000 099096800 9900000000020000 (reserved
[ —— aa E 96999990000e0000 9609000000 100000 e Y
[ E ar y i 3000 (usable
ODO] BIOS e820. 0200000000100000 - 99000000bd0ea000 (usable) |
[ g.869000] B 270. GAGGGG00bd9es000 99900000bd11a000 (reserv
[ 6.966006] BIOS-e820: SsEG00000bdbea ne se peegeed122000 (ACPI data
: E ] -220: 99900000bd114000 0 2 en en
] 0S-e826: 00000 000 (ACPT NVS
a ee ee 00000000bd123000 Se ens rd
a on BI0S-e820: 96000000bd7ab606 chee it re
i nn BTOS-e820: 00000000be336000 96000000be5a/ 00"
rer aise
texto:
ÍRUN_IN_PLACE=no
| INIVAR=inivar
HAL CMD=hal cmd
[LENUXCNC - 2.7.15
ASK=ni 1 task
lar UT=
Fting LinuxCic...
i OS, RTAPL,
10 program
Uinuxencsvr
and HAL LIB modules
358
p LinuxQic...
nents I
lun toading hai
cor puset
rer aise
Last edit: 19 Aug 2021 22:17 by kayovre.
- Thank you received: 7468
19 Aug 2021 23:26 #218186
Replied by tommylight on topic Problema en puerto paralelo, creo.
In terminal:
sudo lspci -v | grep parPlease Log in or Create an account to join the conversation.
- kayovre
20 Aug 2021 08:31 #218220
by kayovre
Replied by kayovre on topic Problema en puerto paralelo, creo.
Muchas gracias por su respuesta, ya lo he solucionado,
de todas formas en mi terminal esa linea no hacia nada, solo he puesto
sudo lspci -v
y mi error era que escribia la letra o en lugar de el numero 0 al poner 0xe000
muchisimas gracias por la ayuda. Un saludo.
sudo lspci -v
Time to create page: 0.217 seconds
