Machine Parts Building
- Akrmmmm
22 Aug 2021 09:38 #218388
by Akrmmmm
Machine Parts Building was created by Akrmmmm
Hey Guys,
I'm currently new in Linuxcnc and the project I'm working at is 4-axis linear delta.
Started to understand the ini. and hal. files and the problem that i'm facing is that i cann't define the machine parts on linuxcnc so i can control it.
if anyone know how to do this I will be grateful.
- Thank you received: 2164
22 Aug 2021 18:33 #218425
Replied by Aciera on topic Machine Parts Building
Not exactly sure what you are asking but there is a kinematic called 'lineardeltakins':
linuxcnc.org/docs/ja/html/man/man9/lineardeltakins.9.html
That would be 3axis I guess.
So do you need an additional C axis like a hand twist?
- yassmin_yasser22148
04 Oct 2021 12:05 #222195
by yassmin_yasser22148
Replied by yassmin_yasser22148 on topic Linear Delta Kinematics
Hello,
Can you tell me the exact path to the file which is called 'lineardeltakins'?
I've found it on the LinuxCNC Github repo and there were 3 lineardeltakins files: lineardeltakins-common.h, lineardeltakins.c, and lineardeltakins.cc.
I'm not able to find any of these files on LinuxCNC on my device?
can you point out the exact path to those files?
Thank You.
Thank You.
04 Oct 2021 15:40 - 04 Oct 2021 17:39 #222204
Replied by Aciera on topic Linear Delta Kinematics
If you have built linuxcnc from source then you should find it here:
your_linuxcnc_folder/src/emc/kinematics/lineardeltakins.c
[edit]
If you have installed through the package manager or the official ISO then it will be somewhere in your root directory.
I don't have such an installation but you could search for it in terminal:
sudo find / -name lineardeltakins.c
It's just been pointed out to me that if you don't have built linuxcnc on your machine then the .c files are not present since you only need to compiled files. So lineardeltakins.c would not be present on a deb install.
[edit]
Last edit: 04 Oct 2021 17:39 by Aciera.
