How to set 1 in G0 X1 to 1MM instead of 1 inch?
26 Aug 2021 09:34 #218777 by wang
Hello everyone
I have a question. Since our commonly used length unit is MM, but linuxcnc defaults the G code length unit to inches, what should I do to set the G code length unit to MM
For example: G0 X1 (1=1MM)
26 Aug 2021 09:55 #218779 by Aciera
In your .ini file [TRAJ]- section set 'LINEAR_UNITS to 'mm':
LINEAR_UNITS = mm
Make sure you also change the machine velocities/accelerations for your configuration.
The following user(s) said Thank You: wang
26 Aug 2021 10:36 #218781 by Clive S
Hello everyone
Also make sure you have G21 at the top of the gcode file
Time to create page: 0.150 seconds
