function of .stl
- @wardania99
26 Aug 2021 13:33 #218796
by @wardania99
function of .stl was created by @wardania99
I tried to use this function (part = AsciiSTL(filename="path/to/file.stl")) as (part = AsciiSTL(newbottom="home/wardania/newbottom.stl")
but show me many different errors
anyone knows how to enter this function in the right way to import file .stl of CAD
- Thank you received: 7468
26 Aug 2021 14:01 #218799
Replied by tommylight on topic function of .stl
What are you trying to do?
LinuxCNC does not work with .stl files ...
Where are you trying to import them ?
- Thank you received: 2164
26 Aug 2021 14:21 - 28 Aug 2021 11:35 #218804
Replied by Aciera on topic function of .stl
You are referring to importing stl files into vismach. I guess.
Try this syntax:
part = AsciiSTL(filename="home/wardania/newbottom.stl")
Note that 'filename' is an argumentparameter of 'AsciiSTL()'.
Try this syntax:
Last edit: 28 Aug 2021 11:35 by Aciera.
26 Aug 2021 14:25 #218806
The following user(s) said Thank You: shpatb
- @wardania99
28 Aug 2021 08:40 #218970
by @wardania99
Replied by @wardania99 on topic function of .stl
what do you mean that filename is a parameter of 'Ascii'
28 Aug 2021 11:32 - 28 Aug 2021 11:38 #218982
What I mean is that the function AsciiSTL() expects an argument called 'filename'.
So if your stl file is called ABCD.stl and you want to call it say 'ABCD-part' in vismach
then you need to call the function like this:
ABCD-part = AsciiSTL(filename="ABCD.stl")
Last edit: 28 Aug 2021 11:38 by Aciera. Reason: I guess it should actually be called an argument of a function and not a parameter
- @wardania99
30 Aug 2021 08:13 #219150
by @wardania99
I tried to enter simplified_structure= AsciiSTL(filename="./simplified_structure.stl") like here linuxcnc.org/docs/html/gui/vismach.html
but show me this error
[Traceback (most recent call last):
File "<stdin>", line 1, in <module>
File "/usr/lib/python2.7/dist-packages/vismach.py", line 899, in _init_
data = open(filename, "r")
IOError: [Errno 2] No such file or directory: './simplified_structure.stl']
Is there a command to import the file or to write the file place
30 Aug 2021 09:09 - 30 Aug 2021 09:14 #219153
Looks like you have an issue with your file path there.
I presume that it expects to find the file in the same folder as your vismach python script but to be sure you might want to use an absolute path (eg. /home/user/linuxcnc/configs...) instead of the relative ./
[edit]
Just in case:
Also remember that linux is case sensitive. ( ie .stl is not the same as .STL)
[edit]
Just in case:
Last edit: 30 Aug 2021 09:14 by Aciera.
- @wardania99
31 Aug 2021 19:52 #219278
by @wardania99
Is should I put the configuration of the machine in vismach library
and then make the script
wiki.linuxcnc.org/cgi-bin/wiki.pl?Vismach
01 Sep 2021 09:26 #219317
I don't think it matters where the configuration is located as long as you have the path right. Have you changed the path to absolute?
Time to create page: 0.096 seconds
