How to quickly get the position of each axis?
- yi2580
- Thank you received: 3
27 Aug 2021 01:30 #218841
by yi2580
How to quickly get the position of each axis? was created by yi2580
Hello, I can ask how I can quickly obtain the position of each axis. The faster the better. How many subtleties or milliseconds can I obtain the position of each axis?
Thank you for your reply
- robertspark
- Thank you received: 216
27 Aug 2021 02:56 - 27 Aug 2021 02:57 #218847
by robertspark
Replied by robertspark on topic How to quickly get the position of each axis?
what do you want to do with the information
a gui is updated every ....
CYCLE_TIME = 100 - Cycle time of the Display GUI. Depending on the screen, this can be in seconds or ms (ms preferred). This is often the update rate rather then sleep time between updates. If the update time is not set right the screen can become unresponsive or very jerky. A value of 100ms (0.1 seconds) is a common setting though a range of 50 - 200ms (.05 - .2 seconds) may be useable. An under powered CPU may see improvement with a longer setting. Usually the default is fine.
servo period is
SERVO_PERIOD = 1000000 - This is the "Servo" task period in nanoseconds
servo period is
Last edit: 27 Aug 2021 02:57 by robertspark.
- yi2580
27 Aug 2021 03:12 #218848
by yi2580
Replied by yi2580 on topic How to quickly get the position of each axis?
Hello, thank you very much for your reply. How can I get these values? I want to use the information of these axes in my own GUI
- yi2580
27 Aug 2021 03:21 #218849
by yi2580
Now I want to use a faster reading speed, which may need to reach the nanosecond level. Now I can use self.status.actual under this def periodic (self) function_ Position [0] to get the position of the axis, but when I use other functions to use self.status.actual_ Position [0] cannot read the position of the axis. I wonder if there is a good solution
01 Sep 2021 22:15 #219369
Replied by andypugh on topic How to quickly get the position of each axis?
I don't think that LinuxCNC even _knows_ the positions at the nanosecond level. It gets position updates from hardware every 1mS.
- yi2580
02 Sep 2021 05:43 #219401
by yi2580
Thank you very much for your reply. If only 1 millisecond is enough, how can I get the axis position every 1 millisecond
02 Sep 2021 09:46 #219422
Presuming that you want to use it in a realtime module, then it is available on HAL pins. (either Axis or Joint pins)
linuxcnc.org/docs/2.8/html/man/man9/motion.9.html#AXIS%20PINS
- yi2580
02 Sep 2021 09:50 #219423
by yi2580
OK, thank you very much. I'll have a good look at this
Time to create page: 0.490 seconds
