python / python3 shebang question
- robertspark
- Thank you received: 216
27 Aug 2021 03:36 #218850
by robertspark
python / python3 shebang question was created by robertspark
I was wondering.....
I had some problems with linuxcnc when I used buildbot to upgrade from 2.8.x to master....
the problems I had were various python files that were not happy.... I know that there has been some frantic work to correct some of the changes from python 2 to python 3.....
however... I noticed (as I'm looking at some files in git) that although the changes to python 3 are being made the shebang (#!) is still pointing to python and not python3
just wondering if this would have an effect on say debian buster where python2 will still be required alongside python 3......
should the shebangs (path to python env) not be changed from python to python3
- Thank you received: 2175
27 Aug 2021 13:05 #218905
Replied by cmorley on topic python / python3 shebang question
The shebang is only relevant if the file is executed directly.
This should explain it better:
stackoverflow.com/questions/6908143/shou...-form-should-it-take
Time to create page: 0.171 seconds
