7i96 (RS 485)
28 Aug 2021 09:29 #218974 by rohit269
7i96 (RS 485) was created by rohit269
Sir,
I want to connect VFD (485+, 485-)  direct connections into 7i96 (TB2 connector TX+,TX-) for spindle speed is it possible.
If possible please tell how to configure this in linuxcnc.
Thanks,
Rohit Gupta
28 Aug 2021 14:05 #219003 by PCW
Replied by PCW on topic 7i96 (RS 485)
Unfortunately that's not possible currently.
The following user(s) said Thank You: zz912
30 Aug 2021 08:38 - 30 Aug 2021 11:54 #219151 by rohit269
Replied by rohit269 on topic 7i96 (RS 485)
Sir,I am attaching a  connection picture of 7i96 to pwm converter to VFD please see this and tells any common GND required for the safety of these all equipments.If required how to common GND between these. Thanks, Rohit Gupta
Last edit: 30 Aug 2021 11:54 by rohit269.
31 Aug 2021 18:46 #219271 by zz912
Replied by zz912 on topic 7i96 (RS 485)
Where is problem?
is the problem, that VFD is half duplex and the mesa is full duplex?
Is the problem joint mb2hal with hostmot2 Uart?
31 Aug 2021 18:57 #219272 by PCW
The problem is that there's no driver support for Modbus --> Mesa PktUART
currently. The PKtUART can do 1/2 duplex with automatic line direction
handling so it not a hardware issue.
31 Aug 2021 19:39 #219277 by rohit269
Thanks for your reply,
sir,
At present I am talking about the PWM wiring connection between these four (power supply, mesa 7i96, pwm converter, VFD) so I am asking how to interconnect 0v between all these four for 7i96 and VFD safety.
Please reply me.
Time to create page: 0.379 seconds
