What is the maximum speed of Linux CNC
- yi2580
- Thank you received: 3
02 Sep 2021 06:26 #219406
by yi2580
What is the maximum speed of Linux CNC was created by yi2580
Ask you a question, what is the speed range of Linux CNC? How should I set its maximum speed in the INI file?
- Thank you received: 7468
02 Sep 2021 11:27 #219427
Replied by tommylight on topic What is the maximum speed of Linux CNC
Why repeating the same questions ?
The maximum speed of LinuxCNC is much more than any normal machine can handle.
In the .INI file the speed is in units per second, so :
max_velocity = 200
means 200mm or inches per second, or 12 meters per minute or 12000 inches per minute.
max_velocity = 200
- robertspark
- Thank you received: 216
02 Sep 2021 13:55 #219436
by robertspark
I think you need to have a read of the manuals and information on LinuxCNC.
What you are asking for is IMPOSSIBLE for any one of us to know or guide you as your machine will be nowhere near similar to my machines or setup and hardware.
You need to tune linuxcnc to YOUR setup and configuration.
There is no easy way or shortcut..... yes there probably are some ways to get close and then tune it accordingly but advise off a 1 line question is a bit like me asking you how fast do you think my car can go and how big or small should the tires be on it or what type and how much oil should I put in the engine...... without knowing the background I'm fairly certain you would not have a clue how to advise me of these items.
start at the top and work your way down:
linuxcnc.org/docs/devel/html/
I read them daily to try to answer my questions and am getting better at knowing where to look.
Replied by robertspark on topic What is the maximum speed of Linux CNC
Time to create page: 0.148 seconds
