Anyone use digital signals to connect 7i96 to a VFD?
- harmo
- Thank you received: 11
It's been a while, so I hope you're all well in these crazy times. I haven't had much time to work on my system, (falling off a ladder and breaking one's arm will do that) so I've been out of touch. I'm not allowed to build the machine, (heavy bits are beyond me still) but I'm currently building the electronics enclosure.. and wiring all the bits inside. It's slow going, but I'm making progress.
Onto my question....
I know most people seem to use the 10V analogue signals to control their VFD from their Mesa card(s) of choice, but I was wondering if anyone has ever used the 24V digital signals?
I have a little 2.2KW Invertek Opti Drive E3, and it seems to have a digital input range of 8-30V or so, so given the Mesa has a 24V I/O... it seems like it might be possible. However, since I can't find anyone who has.... I wonder if it is possible.
If anyone has, I'd like to hear your experiences, considerations, and setup? I just think a higher voltage digital signal might be a little less prone to noise. No aversion to analogue though.
Hope everyone out there is doing ok!
Take care,
Harmo.
- Thank you received: 2177
Do you mean the digital inputs like RUN, FORWARD, REVERSE? That is no problem. But for setting the variable speed I don't see how you could use the digital inputs.I know most people seem to use the 10V analogue signals to control their VFD from their Mesa card(s) of choice, but I was wondering if anyone has ever used the 24V digital signals?
- Thank you received: 7505
Otherwise,never seen a VFD that can be controlled by 8 to 30V, ever, that just seems wrong.
There are 4 to 20 mA inputs on most of them though, so who knows ...
Maybe that is the input OP is talking about as it would be ok for it to be tolerant to those voltages.
- harmo
- hoffb77
I have never used it nor have I seen it used this way but looks to be possible with the right hardware. I'm wondering what you would run the pulse drive with?
So then it would really be limited by the maximum output frequency of the digital outputs of the 7i96. I think 50 kHz may be a bit much but maybe PCW can give you a definitive answer.
A step output should be able to handle the frequency but as far as I'm aware those are all 5V. So you would need to use a reasonably fast optocoupler.
- hoffb77
- Thank you received: 5337
A simple small signal MOSFET (2N7000) would do but if you
wanted isolation a logic opto-isolator would work (say a TLP104)
- harmo
I love how you all just run with my questions. Thanks everyone.
I'm sorry if the topic seems crazy or frivolous, but with lock down, broken bones, pain meds, and "life getting in the way" of CNC progress... these are the things I like to think about.
What if I could use a digital signal? How would I do that? Would there be any tangible benefit? Has anyone done it and why?
Or maybe I'm just suffering from medication-enhanced cabin fever with the household pets using me as a mecca for body warmth.
Like I said, I'm not averse to analogue control, but I always like to consider alternatives.
Hope you're all well, and thanks for the interesting discussion. If anyone does it, I'd love to read about it.
Harmo.
- billykid
- Thank you received: 83
Mauro
