What is the unit of speed?
06 Sep 2021 07:37 #219736 by yi2580
What is the unit of speed? was created by yi2580
Hello, I want to ask, what is the unit of speed here? I feel that it is neither millimeter nor inch per second
  • Moderator
  • Moderator
06 Sep 2021 07:47 #219739 by tommylight
Replied by tommylight on topic What is the unit of speed?
In DRO it is shown as per minute, so that will be 100mm/m or 100inch/m.
14 Sep 2021 01:19 #220539 by yi2580
Replied by yi2580 on topic What is the unit of speed?
Hello, I now know that the unit of speed is mm / min. can I change the unit of speed in ini or other files? Can I change it to mm / s now?
thank you
  • Moderator
  • Moderator
14 Sep 2021 08:59 #220563 by tommylight
Dont know.
It can be changed to inches and back in the ini file, but to /seconds i do not think so, might need to dig deeper into the source code.
Is this for a 3D printer ?
Only printers use mm/s.
14 Sep 2021 09:17 #220565 by yi2580
Dont know.
Yes, I need it to be fast. Mm / min may not meet my current use
Time to create page: 0.126 seconds
