Atc with sevomotor(axis W)
06 Sep 2021 19:19 #219780 by Salar
Atc with sevomotor(axis W) was created by Salar
How to make .ngc for ATC using servo motor(W axis)
09 Sep 2021 17:48 #220071 by andypugh
Replied by andypugh on topic Atc with sevomotor(axis W)
Typically, you wouldn't.
The G-code (ngc) file would just say "T6" (for example) and then other systems logic would move the ATC to the correct position.
Does your ATC have any position feedback separate from the servo encoder?
Time to create page: 0.172 seconds
