MESA 7i92 + 7i77
- HalaszAttila
- Thank you received: 5
09 Sep 2021 13:02 #220052
by HalaszAttila
MESA 7i92 + 7i77 was created by HalaszAttila
Hello,
we often used MESA 5i25 + 7i77ISOL + 7i77 cards for retrofit with analog servos. Now i plan to change 5i25 to ethernet version 7i92 card.
My question is:
should i use 7i77ISOL with ethernet card too, or ISOL card is just for 5i25 cards? 7i92 Ethernet card is galvanically isolated from 7i77?
Thanks,
Attila.
My question is:
Thanks,
Attila.
- Thank you received: 5321
09 Sep 2021 15:14 #220060
Replied by PCW on topic MESA 7i92 + 7i77
The 7I77ISOL is probably not necessary with a 7I92 system because:
1. The 7I92 reference ground can be very close to the drives
2. The 7I92 is galvanically isolated from the Ethernet/connected PC
The 7I92 5V supply should be close to 7I92 (in the drive cabinet)
and have a floating output (so there is a single point ground)
