Spindle encoder feedback
14 Sep 2021 03:13 #220548 by PCW
Replied by PCW on topic Spindle encoder feedback
Is the encoder on the spindle or the motor?
  • Ingo
  • Ingo's Avatar Topic Author
  • Premium Member
  • Premium Member
14 Sep 2021 03:19 #220550 by Ingo
Replied by Ingo on topic Spindle encoder feedback
it's in the motor
  • Ingo
  • Premium Member
  • Premium Member
14 Sep 2021 03:34 #220551 by Ingo
I was thinking…, correct me if I'm wrong: in my .ini file the encoder value is 1000ppr if you multiply by 4x = 4000ppr. There, in Halshow, the spindle feedback signal (pid.s.feedback) will be 133.06/4 = 33.33hz. Multiply 33.33*60hz = approximately 2000rpm. Is that right or am I crazy?
  • Ingo
  • Premium Member
  • Premium Member
17 Sep 2021 03:04 #220852 by Ingo
Could someone please confirm if I'm on the right or wrong path, I'm dizzy...
thanks
17 Sep 2021 03:20 #220854 by PCW
If the spindle runs at 1/2 the motor speed, the encoder in on the motor
and you have a 1000 PPR encoder and you are using quadrature (A and B)
I would expect the proper scale would be 8000 (2 turns of the motor at 4000
counts per turn to rotate the spindle one turn.)
Time to create page: 0.187 seconds
