Howto select line or EMI filter?
- chris@cnc
- Thank you received: 140
11 Sep 2021 15:05 - 11 Sep 2021 15:06 #220226
by chris@cnc
Howto select line or EMI filter? was created by chris@cnc
I am looking for line or EMI filter. The choice is so huge. On what basis I choose this filter.
My machine is 230V, 1 frequency converter 2.2KW spindle, 3 frequency converters with 400W Z, Z + A axis, 80V 1.5KW power supply for X, Y, Y servo motor and 24V 120W power supply.
Maybe someone can give me hint or show me good choice. And is it better for each inverter a small one or use a large one after main switch?
Last edit: 11 Sep 2021 15:06 by chris@cnc.
- Thank you received: 7468
11 Sep 2021 16:39 #220234
On the basis of what i can find !
Not easy to source them here, at all.
Add all the power of everything with at least 30% added for loses, then add 50% on the total.
That should be good.
Or check everything for the max rated current, add those together then add 50% on top.
Replied by tommylight on topic Howto select line or EMI filter?
Time to create page: 0.094 seconds
