axis double joints detach and atach
- fehim
13 Sep 2021 05:57 #220396
by fehim
axis double joints detach and atach was created by fehim
hello all,
My question is about two joint for one axis. We are controlling these joints like another axis as XYZU which need double X axis like XYZX. For G1 codes it is not problem but we can not use G2 codes with this application. We need to pull back joints according to the material's length and first joint should stay and second should move then vice versa. Have you any recommendation to solve this problem? Any help will be appreciated.
thank you
thank you
- Thank you received: 7490
13 Sep 2021 11:11 #220423
Replied by tommylight on topic axis double joints detach and atach
From version 2.8 onwards LinuxCNC can have many joints for the same axis, so you can have any combination of joints/axis.
What version are you using?
- fehim
16 Sep 2021 07:18 #220772
by fehim
Replied by fehim on topic axis double joints detach and atach
We are using 2.7 and we do not have problem with multiple joints in one axis. They are moving together at the same time. But sometimes we want to detach these joints and moving them individually. For example, joint x1 and joint x2 gone 500 together, then I want to move x1 -300 and then x2 -300 respectively. Is it possible or any way to over with this problem?
- Thank you received: 2177
16 Sep 2021 08:29 #220775
linuxcnc.org/docs/devel/html/motion/switchkins.html
The initial motivation for this feature was to be able to switch between trivial and non-trivial kinematics. But you could also use it to switch, as an example, between x1yz and x2yz kinematic. You could even add a third more complex kinematic like (x1+x2)yz. The switching between kinematics can then be done inside a GCode program.
Replied by Aciera on topic axis double joints detach and atach
Maybe the new 'switchable kinematics' feature in the 'master' version could be helpful to you.We need to pull back joints according to the material's length and first joint should stay and second should move then vice versa.
- Thank you received: 1480
16 Sep 2021 19:41 #220811
Replied by Todd Zuercher on topic axis double joints detach and atach
I've done something similar to this using only some complex hal trickery.
I have a couple of machines with two parallel Z axis, set up as Z and W. I wanted the ability to temporarily slave them together so I could run the machine as XYZZ (mostly because the new trajectory planner didn't work for W.) But I wanted to retain the ability to move each Z and W separately for homing and touching off and setting tool depth. So I set up the tools and set the Z and W offsets. Then start the milling file the Z and W move independently to a coordinated starting point above the material. A custom M-code is issued that slaves the W head to the Z axis and the file is ran using only XYZ commands. At the end of the file, another custom M-code unslaves the W axis and each head moves independently again back to their park positions at the top of their axis travels.
Here is a link to where I posted some example configurations for both step/dir and analog servos.
forum.linuxcnc.org/forum/38-general-linu...e-questions?start=20
The following user(s) said Thank You: tommylight, Aciera
- fehim
17 Sep 2021 11:22 #220880
by fehim
Thank you sir. I will try your advice
Time to create page: 0.133 seconds
