(Solved?) Feed override encoder reset
4 years 3 months ago #247270 by tightmopedman9
Thanks for the advice, but I added the exported hal line into my custom_config.yml before implementing this code. As I said in my last post, I can see that the pins exist when I open halmeter/halshow.
Is there any possibility that my custom_postgui.hal is getting loaded before the pins are created? I can see the probe basic header bar pop up for just a second before closing and displaying the error. I attached the full text of the error in a text attachment to this post.
4 years 3 months ago - 4 years 3 months ago #247271 by spumco
Replied by spumco on topic Feed override encoder reset
Sorry, completely overlooked the part where indicated you'd done the .yml and could see them in halshow.
That's a new one on me.  The only thing I can think of - besides the file load timing as you pointed out - is a pin name spelling error.  But those look good to me, too.
Probably want to move this to qtpyvcp forum and see if the devs have some thoughts on it.
EDIT - just noticed something.  Your feed override IS loading, but the speed override isn't.  Try changing the pin name to: qtpyvcp.spindle-override.reset and see if that helps.
Last edit: 4 years 3 months ago by spumco. Reason: Ah-HA!
4 years 3 months ago #247272 by tightmopedman9
Amazing! Great catch! I feel like an idiot for not seeing that myself. Thanks for the help.
4 years 3 months ago #247274 by spumco
Yea, that sort of thing has NEVER happend to me or anyone else...image missing /media/kunena/emoticons/unsure.png
Pay it forward next time you see someone struggling.  Remember, it's us against Linux.
4 years 2 months ago #249256 by pippin88
Yes, I had the same thought this morning t and I've just added the following reset pins
halui.feed-override.reset
halui.rapid-overide.reset
haui.spindle.n.override.reset
Initial testing seems ok, but I'll wait until I've tested it properly at the weekend before raising a pull request
One thing I did notice some strange behaviour but it's the same with the GUI slider - its hard to get the value to go past 112% - I suspect its an artefact of the conversion from int to float.
Russell - can you share the code for this?
I need this function (I have MPG, hardware feed buttons, and the GUI feed slider).
It should be incorporated into halui.
