- LinuxCNC
- General LinuxCNC Questions
- How should the speed of G code and display interface modify them
- yi2580
- Thank you received: 3
15 Sep 2021 01:21 #220665
by yi2580
How should the speed of G code and display interface modify them was created by yi2580
Is there a way to change the speed unit from mm / min to mm / S (the speed unit of the display interface and G code is mm / min). What should I do to modify it.
- Thank you received: 2164
15 Sep 2021 06:52 #220676
Replied by Aciera on topic How should the speed of G code and display interface modify them
Not sure why you keep opening new threads for the same topic.
As for changing the speed unit, I don't think that is possible. If your GCode contains the feed rates in mm/s you might want to have a look at creating a custom Gcode converter to change the mm/s to mm/min when the file is loaded. See section 2.3:
linuxcnc.org/docs/html/config/ini-config.html
- Thank you received: 7468
15 Sep 2021 08:30 #220682
Replied by tommylight on topic How should the speed of G code and display interface modify them
Last night i deleted another post with the same topic as it has been answered on yet another thread.Not sure why you keep opening new threads for the same topic.
- LinuxCNC
Time to create page: 0.090 seconds
