I hope this is the correct forum but I have one of the T60 stepper drivers and motors but am having a great deal of trouble getting any response out of it.
The motor locks up when power is applied to the driver so that side is ok.
If I use a different driver the motor will move so the windings are probably ok.
The T60 driver shows a blinking green light at all times which means it is ready and has no faults.
But when a direction signal is sent from the BOB to the drive there is no response. If I change over the connections to a HSS57 driver and motor everything works fine.
The BOB is feed with a solid 12v supply and not the usual 5v from the usb connection. The signal cables show 5v signal at the step and direction terminals.
The minimum pulse signal for both the controllers is 7mA.
the step space and time are 500ns, direction hold 5000ns, direction setup 1000ns. These timings work fine with the HSS57 controller, so I would assume ok with the T60 as well.
I am now at a bit of a loss so any help gratefully received!!
thanks
