- LinuxCNC
- General LinuxCNC Questions
- screwcompX.dat value unit is mm or inch? can the accuracy to be 0.1um?
- curran209
17 Sep 2021 09:38 #220868
by curran209
screwcompX.dat value unit is mm or inch? can the accuracy to be 0.1um? was created by curran209
\linuxcnc-master\configs\sim\screwcompX.dat
-10 -10.001 -9.999
-8 -8.001 -7.999
-6 -6.002 -5.999
-4 -4.2 -3.998
-2 -2.003 -1.998
0 -0.003 0.002
2 1.997 2.003
4 3.997 4.002
6 5.998 6.001
8 7.999 8.001
10 9.999 10.000
-10 -10.001 -9.999
-8 -8.001 -7.999
-6 -6.002 -5.999
-4 -4.2 -3.998
-2 -2.003 -1.998
0 -0.003 0.002
2 1.997 2.003
4 3.997 4.002
6 5.998 6.001
8 7.999 8.001
10 9.999 10.000
- Thank you received: 2164
17 Sep 2021 11:11 - 17 Sep 2021 11:13 #220878
Replied by Aciera on topic screwcompX.dat value unit is mm or inch? can the accuracy to be 0.1um?
Really not sure why you _keep_ insisting on opening new threads for every new question about this topic. It's just a nuisance and makes no sense at all.
Anyway I would think the units to be the same as your machine units defined in your ini. I don't see why you couldn't use four decimal places in the comp file.
Mind you, it would very much depend on your application whether such resolutions actually made any sense at all.
Last edit: 17 Sep 2021 11:13 by Aciera.
- Thank you received: 7468
17 Sep 2021 14:22 #220899
Use the old thread/topic, the first one you started as whenever i get a bit of time i will clean these up.
Replied by tommylight on topic screwcompX.dat value unit is mm or inch? can the accuracy to be 0.1um?
+1Really not sure why you _keep_ insisting on opening new threads for every new question about this topic. It's just a nuisance and makes no sense at all.
- LinuxCNC
Time to create page: 0.445 seconds
