Greetings all,
I am trying to use my 7i76e's analog spindle speed capabilities, but I can not get the potentiometer to function.
Spindle: Makita router (0-5V fed through a 100K pot, now replaced with the 7i76e digital pot)
RPM: 10,000 @ 0V -to- 30,000 @ 5V
For debugging, I have a 10v power supply connected to the digital pot. I read low millivolts between wiper and signal regardless of MDI "M3 S#####" commands. The wiper stays firmly at the 0V end of the range, which corresponds to 10,000 rpm. Wiper to positive reads 10V (as expected).
I had the analog output working previously with a VFD, but I can't seem to get it to work now. There seems to be a disconnect between my configuration files (attached) and the mesa board.
Any help would be greatly appreciated.
Thanks,
Tanner Frisby
