interpreter crashes at tooldata_find_index_for_tool
- Reinhard
- Thank you received: 94
26 Sep 2021 08:39 #221620
by Reinhard
interpreter crashes at tooldata_find_index_for_tool was created by Reinhard
I try to internally use the interpreter in a Qt-app and I hope, that it will be faster, than parsing text output from interpreter on my own.
As always I try to follow axis code ...
I use qtcreator with debugger to narrow the problem. In the loop of read/execute crash happens at execute with this stack-trace:
For check I run axis with the same config/gcode-file and there's no problem.
In my java-app I use the ready compiled interpreter-executable, so I tried that too and got some strange result. I call the interpreter with "rs274 -g -v [var-file] -i [ini-file] -t [tool-table] -n 0 -l 999 2> error.log > log"
Here's the log:... and these are the errors:
Axis or backend don't report any errors using same files.
Tool-Table is this:
- tool_mmap_mutex_get (tooldata_mmap.cc #79)
- tooldata_find_index_for_tool (tooldata_mmap.cc #298)
- Interp::find_tool_index (interp_find.cc #722)
- Interp::convert_tool_select (interp_convert.cc #5704)
- Interp::execute_block (interp_execute.cc #300)
- Interp::_execute (rs274ngc_pre.cc #504)
- Interp::execute (rs274ngc_pre.cc #533)
Here's the log:
1 N..... USE_LENGTH_UNITS(CANON_UNITS_MM)
2 N..... SET_G5X_OFFSET(1, 8165.0024, 12700.0000, -5080.0000, 0.0000, 0.0000, 0.0000)
3 N..... SET_G92_OFFSET(3004.1677, 209.2678, 78.7400, 0.0000, 0.0000, 0.0000)
4 N..... SET_XY_ROTATION(0.0000)
5 N..... SET_FEED_REFERENCE(CANON_XYZ)
6 N..... ON_RESET()
7 N..... SELECT_PLANE(CANON_PLANE_XY)
8 N..... USE_LENGTH_UNITS(CANON_UNITS_MM)
9 N..... COMMENT("interpreter: continuing to use same coordinate system")
10 N..... SET_MOTION_CONTROL_MODE(CANON_EXACT_PATH)
11 N..... COMMENT("interpreter: cutter radius compensation off")
12 N..... USE_TOOL_LENGTH_OFFSET(0.0000 0.0000 0.0000, 0.0000 0.0000 0.0000, 0.0000 0.0000 0.0000)
13 N..... COMMENT("interpreter: motion mode set to none")
14 N..... SELECT_TOOL(3)
15 N..... START_CHANGE()
16 N..... STOP_SPINDLE_TURNING(0)
17 N..... COMMENT("AXIS,hide")
18 N..... STRAIGHT_TRAVERSE(-11169.1702, -12909.2678, 5001.2600, 0.0000, 0.0000, 0.0000)
19 N..... COMMENT("AXIS,show")
20 N..... CHANGE_TOOL(2)
21 N..... USE_TOOL_LENGTH_OFFSET(0.0000 0.0000 1346.2000, 0.0000 0.0000 0.0000, 0.0000 0.0000 0.0000)
22 N..... SELECT_TOOL(1)
23 N..... STRAIGHT_TRAVERSE(50.0000, 50.0000, 3655.0600, 0.0000, 0.0000, 0.0000)
24 N..... STRAIGHT_TRAVERSE(50.0000, 50.0000, 30.0000, 0.0000, 0.0000, 0.0000)
25 N..... SET_SPINDLE_SPEED(0, 3000.0000)
26 N..... START_SPINDLE_CLOCKWISE(0)
27 N..... FLOOD_ON()
28 N..... STRAIGHT_TRAVERSE(50.0000, 50.0000, 10.0000, 0.0000, 0.0000, 0.0000)
29 N..... SET_FEED_RATE(250.0000)
30 N..... STRAIGHT_FEED(50.0000, 50.0000, 0.0000, 0.0000, 0.0000, 0.0000)
31 N..... COMMENT("interpreter: cutter radius compensation on left")
32 N..... SET_FEED_RATE(2000.0000)
33 N..... MIST_OFF()
34 N..... FLOOD_OFF()
35 N..... COMMENT("interpreter: cutter radius compensation off")
36 N..... START_CHANGE()
37 N..... STOP_SPINDLE_TURNING(0)
38 N..... COMMENT("AXIS,hide")
39 N..... STRAIGHT_TRAVERSE(50.0000, 50.0000, 3655.0600, 0.0000, 0.0000, 0.0000)
40 N..... COMMENT("AXIS,show")
41 N..... CHANGE_TOOL(7)
42 N..... USE_TOOL_LENGTH_OFFSET(0.0000 0.0000 3124.2000, 0.0000 0.0000 0.0000, 0.0000 0.0000 0.0000)
43 N..... MESSAGE(" optional stop, i.e. for cleaning the workpiece, or other thinks")
44 N..... OPTIONAL_PROGRAM_STOP()
45 N..... STRAIGHT_TRAVERSE(50.0000, 50.0000, 1877.0600, 0.0000, 0.0000, 0.0000)
46 N..... STRAIGHT_TRAVERSE(50.0000, 50.0000, 10.0000, 0.0000, 0.0000, 0.0000)
47 N..... SET_SPINDLE_SPEED(0, 6000.0000)
48 N..... START_SPINDLE_CLOCKWISE(0)
49 N..... MIST_ON()
50 N..... STRAIGHT_TRAVERSE(50.0000, 50.0000, 10.0000, 0.0000, 0.0000, 0.0000)
51 N..... SET_FEED_RATE(400.0000)
52 N..... STRAIGHT_FEED(50.0000, 50.0000, 1.0000, 0.0000, 0.0000, 0.0000)
53 N..... COMMENT("interpreter: cutter radius compensation on left")
54 N..... SET_FEED_RATE(1000.0000)
55 N..... MIST_OFF()
56 N..... FLOOD_OFF()
57 N..... STOP_SPINDLE_TURNING(0)
58 N..... SET_G5X_OFFSET(1, 8165.0024, 12700.0000, -5080.0000, 0.0000, 0.0000, 0.0000)
59 N..... SET_XY_ROTATION(0.0000)
60 N..... SET_FEED_MODE(0, 0)
61 N..... SET_FEED_RATE(0.0000)
62 N..... STOP_SPINDLE_TURNING(0)
63 N..... SET_SPINDLE_MODE(0 0.0000)
64 N..... PROGRAM_END()
65 N..... ON_RESET()executing
Radius of cutter compensation entry arc is not greater than the tool radius
G3 X70 Y50 Z-1 I10 J0
G3 I -20
G3 X50 Y50 Z1 I-10 J0
Length of cutter compensation entry move is not greater than the tool radius
G0 Z30
G3 X65 Y50 Z-1 I7.5 J0
G3 I-15
G3 X50 Y50 Z1 I-7.5 J0
G0 Z30
G0 Z30
G0 X50 Y50Axis or backend don't report any errors using same files.
Tool-Table is this:
T2 P1 Z20 D2 ;2.00mm 4 schneiden fräser
T3 P2 Z53 D3 ;3.00mm 2 flute endmill
T6 P3 Z30 D6 ;6.00mm 4 schneiden fräser
T4 P5 Z40 D8 ;8,00mm 4 schneiden fräser
T7 P8 Z50 D12 ;12,00mm 4 schneiden fräser
T1 P9 Z123 D4.568 ;45 deg v cutterPlease Log in or Create an account to join the conversation.
- Reinhard
29 Sep 2021 14:08 #221832
by Reinhard
Replied by Reinhard on topic interpreter crashes at tooldata_find_index_for_tool
I got a bit further with testing. My prototype for testing is available
With that prototype I can compare internal and external interpreter usage. When I use an oldstyle rip installation (with configure --enable-toolnml) everything works fine. Same is true, if external interpreter is used.
With a new style rip installation interpreter crashes with above stacktrace.
This crash is reproducible using sample gcode file from linuxcnc: gmoccapy_2_tools_with_cutter_radius_compensation.ngc
It seems, that tooldata_find_index_for_tool lacks some check for valid tool_mmap_base.
*hptr is NULL.
I don't know, whether I should have initialized that in my app.
So I'm asking for help.
*hptr is NULL.
Time to create page: 0.116 seconds
