- Thank you received: 10
cannot get named subroutine to work
- ericg
- Topic Author
5 years 1 month ago #221692
by ericg
cannot get named subroutine to work was created by ericg
I have this annoying issue that my subroutines work fine when called by number from MDI_COMMAND =, e.g o100 call but when I name them I get a "unknown word where unary operator could be" error message either from the program or manually from the MDI panel
The path is correct and the names are all lowercase so I'm lost as to what the issue is.
I have included as attachments my .ini and probe.ngc file.
any help appreciated
Eric
Eric
- MaHa
- Thank you received: 241
5 years 1 month ago - 5 years 1 month ago #221694
by MaHa
Replied by MaHa on topic cannot get named subroutine to work
I think subroutines need M2 or M30 at the end. To comment in gcode use () or ;
while # is part of numbered or named parameters as #444, #<SOS>, #<_SOS>
Last edit: 5 years 1 month ago by MaHa.
- ericg
- Topic Author
5 years 1 month ago #221697
by ericg
Replied by ericg on topic cannot get named subroutine to work
YESSS!!! thank you MaHa, that was it - the # which I thought was a comment like in the rest of LCNC, guess I need to learn more about Gcode protocols
Eric
Eric
Time to create page: 0.097 seconds
