Unwanted drive to the tool change point. (Run from there)
- Adam Maszynotwór
- Thank you received: 12
29 Sep 2021 00:16 - 29 Sep 2021 09:20 #221794
by Adam Maszynotwór
Unwanted drive to the tool change point. (Run from there) was created by Adam Maszynotwór
Hello, I have the following problem when I start the program not from the beginning and in the middle - let's say from the T10 tool. What happens in the movie, i.e. the machine in turn with each tool that was before this tool, T10 goes to the exchange point, asks for its replacement, then the piece comes over the detail returns to the exchange point and so on until it comes to this tenth tool
I would like to add that ProbeScreen V2 is responsible for the automatic replacement, but the tool length measurement is not active ..
Anyway, I think that it should not matter and the program should start from where the machine is standing and execute the block that I chose with the "Run from here" button, if there is, for example, g00 Z15, I would like the machine to rise by 15 mm up and she was not going to replace all the tools in turn.
What is a Linux setup bug or is it just the way it works and there's nothing you can do about it?
Additional questions: Is it possible in linuxcnc to do a tool change without changing at the tool change point or tool magazine?
On machines with HH, the appropriate code allows you to change the tool manually, e.g. I have a T10 in the spindle and we manually put T15 on HH, I choose the appropriate M code and the machine programmatically changes and sees that it has T15 but does not go to the tool magazine for it
I'm sorry if the topic was touched, it's hard for me to look for English
Witam mam następujący problem gdy uruchamiam program nie od początku a w środku - powiedzmy z narzędzia T10. Co dzieje się na filmie czyli maszyna po kolei z każdym narzędziem które było przed tym narzędziem, T10 jedzie do punktu wymiany, prosi o jego wymianę, potem kawałek przejeżdża detal wraca do punktu wymiany i tak dalej aż przyjdzie do tego dziesiątego narzędzia
dodam, że za automatyczną wymianę odpowiada ProbeScreen V2, ale pomiar długości narzędzia nie jest aktywny..
Zresztą uważam, że nie powinno to mieć znaczenia i program powinien startować od miejsca, w którym stoi maszyna i wykonać blok, który wybrałem przyciskiem „Uruchom stąd”, jeśli jest np. g00 Z15 to chciałbym maszyna podniosła się o 15 mm w górę i nie zamierzała wymieniać po kolei wszystkich narzędzi.
Co to jest błąd konfiguracji Linuksa, czy po prostu tak to działa i nic nie możesz na to poradzić?
Dodatkowe pytania: Czy w linuxcnc można dokonać wymiany narzędzia bez zmiany w punkcie wymiany narzędzi lub magazynie narzędzi?
Na maszynach z HH odpowiedni kod pozwala na ręczną zmianę narzędzia np mam T10 we wrzecionie i ręcznie wkładamy T15 na HH wybieram odpowiedni kod M i maszyna programowo zmienia i widzi że ma T15 ale nie idzie po to do magazynu narzędzi
przepraszam jeśli temat został poruszony, ciężko mi poszukać angielskiego
Last edit: 29 Sep 2021 09:20 by Adam Maszynotwór.
- nkp
- Thank you received: 39
29 Sep 2021 01:45 #221795
by nkp
Replied by nkp on topic Unwanted drive to the tool change point. (Run from there)
M61 Q15
The following user(s) said Thank You: Adam Maszynotwór
- Adam Maszynotwór
01 Oct 2021 01:32 #221931
by Adam Maszynotwór
Replied by Adam Maszynotwór on topic Unwanted drive to the tool change point. (Run from there)
Thank you M61 Q15 works fine
I still don't know what I can do with the most important problem - A program started with e.g. N2500 changes all tools one by one until it reaches N2500.
Why is this happening? how to disable / change it
It seems to me that everyone who has manual or automatic exchange has a problem with it - please check it out
This is rather a wrong operation of Linuxcnc itself - e.g. if I have a T-cutter in a slot and I want to resume the program from the G01 X100 F100 line, the program should go to X100 and that's it, and not analyze the program from N1 and change the tools until it reaches the one currently works.
Time to create page: 0.541 seconds
