7i95 NPN proximity sensor wiring
  • mittim
  • mittim's Avatar Topic Author
  • Premium Member
  • Premium Member
02 Oct 2021 12:19 #222008 by mittim
7i95 NPN proximity sensor wiring was created by mittim
I am currently wiring my 7i95 inputs and stumbled upon the difference between using NPN and PNP sensors. The data sheet of the 7i95 says:
"For sinking type inputs, the input common pin for a given input pair is grounded and a +4 to +36V signal is applied to the input pins to activate the input". I am using NPN proximity sensors. Is my wiring correct?
Thanks in advance!
02 Oct 2021 13:00 - 02 Oct 2021 13:04 #222011 by 0x2102
Replied by 0x2102 on topic 7i95 NPN proximity sensor wiring
For NPN you would connect:
COMMON 0,1 to 5V or 24V (24V preferred)
Pin0 to your NPN signal (NPN will switch GND to SIGNAL)
NC / NO (normally closed or normally open) can handled in your HAL file.
There are two PINs for your Input-00 e.g.:
hm2_7i95.0.inmux.00.input-00 and hm2_7i95.0.inmux.00.input-00-not
Last edit: 02 Oct 2021 13:04 by 0x2102.
  • mittim
  • Premium Member
  • Premium Member
02 Oct 2021 13:45 #222014 by mittim
Replied by mittim on topic 7i95 NPN proximity sensor wiring
Thanks,
so, the wiring would lool like this:
02 Oct 2021 15:22 #222023 by 0x2102
Correct.
02 Oct 2021 16:49 #222032 by PCW
Replied by PCW on topic 7i95 NPN proximity sensor wiring
I should re-write that manual page to include the sensor type
It's not clear that "sinking inputs" refers to the 7I95 input not the sensor
Sinking inputs connect to sourcing sensors (PNP sensors)
Sourcing inputs connect to sinking sensors (NPN sensors)
The following user(s) said Thank You: Unlogic
  • mittim
  • Premium Member
  • Premium Member
02 Oct 2021 20:57 #222049 by mittim
Yes, that´s exactly what confused me.
Time to create page: 0.173 seconds
