Pin out direction.
- Willheg
03 Oct 2021 00:07 #222065
by Willheg
Pin out direction. was created by Willheg
Hello all,
I was unsure where to post this but i have another question I'd like to ask.
I have a laser etcher and have it hooked so I turn it on and off via a relay and at this stage a custom M code (M107/M108 for main laser power on/off, M105/M106 for laser burn/not), my issue is that when I turn everything on the relay is powered "ON" due to my BOB, but when i start LinuxCNC it flips the relay off.
Just wondering if there is a way to control this so it does not change state until told so via g-code. I have tried using a startup gcode but this did nothing as i think it is to early before it has assigned everything else, and I tried using the invert signal in the *.hal file but this seams to reset it every cycle time, i just want a "one shot" on startup if that is possible.
Hopefully this is not to difficult and that i have missed something simple, but i will keep looking unless anyone has any ideas to offer.
Thanks for reading and answering if anyone does either of those.
Will
Will
- Thank you received: 7488
04 Oct 2021 22:18 #222233
Replied by tommylight on topic Pin out direction.
PC's will send service data to parallel port during boot, and i am not aware of a standard for that, so the best way would be to change the pin and reboot, if it does flip > change pin and reboot again. Pretty sure some pins do not change state during boot time.
- Willheg
07 Oct 2021 09:27 - 07 Oct 2021 09:29 #222435
by Willheg
Replied by Willheg on topic Pin out direction.
Thanks Tommylight,
Forgot to say I'm running a PCI card as well if that makes a difference.
Dam that sounds annoying as i have used all my other output pins at this point, I'll keep trying to think of a way to get round this if I can.
Might just be easier to have a manual on/off switch somewhere and have the g-code pause with a message window saying turn on maser laser power or something, I mean I need to remove the previous tool before running the laser anyway.
Anyway I will keep thinking and see what if anything I can come up with in time.
Cheers
Will
Cheers
Will
Last edit: 07 Oct 2021 09:29 by Willheg.
07 Oct 2021 10:18 #222439
They remain low until LinuxCNC tells them differently.
It does, pins on add on cards do not change during boot, at least not on over 15 of them i used.
- Thank you received: 1480
07 Oct 2021 16:38 #222468
Replied by Todd Zuercher on topic Pin out direction.
Can you set up your BOB to use a charge pump, so that everything will be held in a known state until Linuxcnc is in control?
07 Oct 2021 21:06 #222490
Replied by andypugh on topic Pin out direction.
Alternatively, use a 5i25 instead of a PCI parallel port. It costs several times more money, but can step literally 100x faster. (and PWM faster too, possibly useful for a laser)
Time to create page: 0.218 seconds
