Linuxcnc lathe threading problem
5 years 3 weeks ago - 5 years 3 weeks ago #222558 by rohit269
Sir,
I am converted mach3 lathe to linuxcnc lathe and also change spindle rpm sensor disc (16 slot) and this linuxcnc lathe not make threading  correctly and the thread has been always damaged and I am also attached files please see files and tell how to  solve this problem.
Many thanks,
Rohit Gupta
Last edit: 5 years 3 weeks ago by rohit269.
5 years 3 weeks ago #222576 by zz912
if you want to run LCNC reliably, do not use a parallel port and buy a mesa card. 7i96 or 7i76e for example. However, if you want to find an error on the parallel port at all costs, you need to find out if the steps on the encoder or on the Z axis are lost or both.
Make an empty thread a few times and then measure whether the spindle and axes return to the home position.
5 years 3 weeks ago #222607 by andypugh
I don't see any evidence of an index, you seem to have only one sensor and 16 slots. So the system does not know when to start the threading pass.
You need a once-per-rev index as well as the 16 pulses. (Or, in the development version, there is an option to use missing-tooth index)
5 years 3 weeks ago #222623 by rohit269
Many thanks for supporting me,
Sir I am already connected spindle sensor single output into two pin 11 and 12 for index and Spindle phase A but thread always damaged.
5 years 3 weeks ago - 5 years 3 weeks ago #222683 by Dinuka_Shehan
i used omron quadrature encoder.
It have A,B & Z phases.
Easy to connect.
Last edit: 5 years 3 weeks ago by Dinuka_Shehan.
5 years 3 weeks ago #222824 by andypugh
The index must be once-per-revolution. My impression is that you have 16 indexes per revolution?
Time to create page: 0.246 seconds
