shallow arcs - large radius - milling machine limits
09 Oct 2021 23:18 #222701 by dansawyer
The project is to mill a shallow arc in a shorter piece of aluminum The aluminum blank is 4 inches long by 2 inches wide. For this question lets say the mill bed has an 8x8 movement range. Let's assume the blank is mounted to allow the bed to cover the entire blank My question is will CNC limits allow cutting an arc with a radius 12 inches from the blank?
The core of the question is: will LinuxCNC allow a reference that is beyond the bed limits ?
09 Oct 2021 23:56 #222702 by MaHa
The toolpath matters. As long it is within machine limits, you can machine any contour or radius.
12 Oct 2021 22:10 #222977 by andypugh
Yes.
Time to create page: 0.133 seconds
