Hi all
I think there is a bug in the homing procedure , speciali at home index only
in fact , when send it to home ( rotary axis) with index only , without home switch it start rotaiting up to the limit of the axis in the ini file without get it homed releasing limit error. any attempt after this will home the axis till the power is off
home switch is not a good idea on rotary axises as it will be hit many times.
and here is the ini part. limits are extended over 360 degree for testing purposes
There was a reply on the IRC from cradek about this, after you had left.
cradek_:
linuxcnc.org/docs/2.8/html/config/ini-homing.html
[02:01am] cradek_: for index-only homing you need HOME_USE_INDEX=yes, but you didn't show that. is it set right? is your index actually working?
[02:02am] cradek_: oh, he left. sigh.
