How to add debug select when building linuxcnc source code?
12 Oct 2021 09:25 #222910 by curran209
Building linuxcnc source code need using make comand.
13 Oct 2021 23:36 #223048 by andypugh
I don't fully understand your question.
LinuxCNC has a few separate debug levels that might be set. They all control the debug level of different things.
There is an entry in the INI, but I suspect that you don't mean that.
linuxcnc.org/docs/2.8/html/config/ini-config.html#_emc_section
You can add a line of code in a relevant place:
linuxcnc.org/docs/2.8/html/man/man3/rtap...sg_level.3rtapi.html
(you used to be able to set this with echo 5 > /proc/rtapi/debug but something broke that).
Try "man debuglevel" for another way. (basically issue the "debuglevel" command in a terminal window when LinuxCNC is running)
And then there is the option of adding debugging at the kernel level:
github.com/LinuxCNC/linuxcnc/blob/2.7-buster/docs/rtfaults.txt
14 Oct 2021 03:34 #223056 by curran209
I want to debug my new code added in linuxcnc project with gdb . How can i add debug selection when building? Because use gcc -g when i building a small project.
14 Oct 2021 08:01 #223065 by andypugh
The last link in my reply above says where the -g flag should be inserted.
Time to create page: 0.090 seconds
