How many is the Interpolation cycle of linuxcnc?
- curran209
14 Oct 2021 06:18 #223058
by curran209
How many is the Interpolation cycle of linuxcnc? was created by curran209
How many is the Interpolation cycle of linuxcnc? Can i change it?
- robertspark
- Thank you received: 216
14 Oct 2021 07:33 #223061
by robertspark
Replied by robertspark on topic How many is the Interpolation cycle of linuxcnc?
interpolation of what exactly?
timing?
motion?
please explain your question, thanks
timing?
motion?
- curran209
14 Oct 2021 07:49 #223064
by curran209
Replied by curran209 on topic How many is the Interpolation cycle of linuxcnc?
time.
Interpolation period
the period of interpolation calculations
What's the meaning of "#define INTERPOLATION_RATE_SET 0x02" in cubic.c? Is the interpolation period 2ms? Can it set to 1ms or more fast?
- curran209
14 Oct 2021 08:51 #223066
by curran209
Does SEGMENT_TIME_SET is Interpolation period, what's it unit? Can it set to be smaller?
- Thank you received: 4652
14 Oct 2021 15:54 #223092
Replied by andypugh on topic How many is the Interpolation cycle of linuxcnc?
I suspect that nobody has looked at that code for decades, so it is likely that nobody currently active knows what it does.
I would guess that the thing to do is look through the code for the usage of those macros.
I would be very surprised if a hex integer was used as an interpolator rate, though.
