Live plot and position display lost
- spi
- Thank you received: 8
14 Oct 2021 17:40 #223100
by spi
Live plot and position display lost was created by spi
This is using a 2.9 from about a month ago and Axis and the issue is that in the preview view all the live data (axis position labels, cone, live plot) simply disappear after running for about one hour. I haven't figured out a way to get them back except restarting lcnc. Is this a known issue?
Thanks!
Seppo
Thanks!
Seppo
- Thank you received: 7468
14 Oct 2021 20:59 #223118
Replied by tommylight on topic Live plot and position display lost
No it is not a known issue, it is usually due to graphic cards that are integrated in the chipset or processor, usually 915/945 old Intels and some new-ish ones.
If it is a normal PC, try adding a graphic card, ATI/AMD do work mostly, NVIDIA not so much.
Time to create page: 0.075 seconds
