The difference between LinuxCNC components and LinuxCNC driver?
  • tuzki
  • tuzki's Avatar Topic Author
  • Senior Member
  • Senior Member
17 Oct 2021 14:23 #223381 by tuzki
Hello everyone. I am a novice. I don't understand the difference between components and drivers in LinuxCNC. I think the LinuxCNC component is a small functional module with software implementations of various operations. The LinuxCNC driver is also a small functional module, but it will communicate with the hardware
Do i understand it this way?
17 Oct 2021 15:17 #223389 by PCW
Yes, that's basically correct, most components communicate to other
components via hal but its not really a clear distinction and as some
components do communicate to hardware, modbus for example.
  • tuzki
  • Senior Member
  • Senior Member
26 Oct 2021 06:45 #224335 by tuzki
Thank you for your answer
  • tuzki
  • Senior Member
  • Senior Member
26 Oct 2021 11:51 #224380 by tuzki
Time to create page: 0.069 seconds
