Stepping a program - bug or feature?
- spumco
- Thank you received: 896
20 Oct 2021 13:05 #223663
by spumco
Stepping a program - bug or feature? was created by spumco
I've been trying to set up my external program controls (cycle-start, single-block, etc.) and discovered something that is confusing me.
Load a program, press cycle-start (on screen, or external using halui.program.run) and LCNC runs through the program one line at a time. So far, so good.
When I use program step mode, the behavior changes depending on the G-code. If a line has movement pressing step (or halui.program.step) will execute one line and then LCNC waits for another input.
However, if the G-code line has no movement in it pressing step once will continue executing line after line until it reaches a line with movement. That line with movement will be executed and only then LCNC stops.
GUI being used makes no difference, nor if on-screen buttons or external controls using halui.program.whatever are used.
Example 1 (expected behavior)
[press STEP]
G1 X0 F10 <= line is executed, LCNC stops here
[press STEP]
G1 X1 F10 <= line is executed, LCNC stops here
G1 X0
G1 X1
G1 X0
M30
Example 2 (unexpected behavior)
[press STEP]
[press STEP]
G1 X1 <= line is executed, LCNC keeps going
M8 <= line is executed
G4 P1 <= line is executed
M9 <= line is executed
G1 X0
M30
This behavior does not match any other controller I've used (Mach3, UCCNC, Fanuc, HAAS, Siemens, Fadal). In all other controllers, single-block (or whatever it's called) will execute one line of code and that's it.
Is this a bug or expected/desired behavior? I realize it's unusual to have many non-movement lines of code, but I'd like to understand the intended behavior of LCNC and there's nothing in the documentation about this particular detail.
Thanks,
Ralph
[press STEP]
[press STEP]
G1 X0
G1 X1
G1 X0
M30
[press STEP]
[press STEP]
G1 X0
M30
Thanks,
Ralph
- Thank you received: 4652
20 Oct 2021 13:10 #223664
Replied by andypugh on topic Stepping a program - bug or feature?
I think that it is intended, or at least it is inherent to the way that LinuxCNC works.
Motion commands have serial numbers, and are queued with a serial number.
Modal commands don't get serial numbers, and the controller has no idea if they came from one or many program lines.
- spumco
20 Oct 2021 13:19 #223666
by spumco
Replied by spumco on topic Stepping a program - bug or feature?
Thanks Andy, at least I'm not crazy watching my machine plow through line after line even though I've got it in 'single-block' mode.
I wonder if this applies to M-codes that don't have direct G-code commands... i.e. a tool-change sequence?
Can you envision a scenario where you are in single-block/step and the next line is a tool-change with re-mapped M6?
If there's no explicit G0/G1/G2/G3 move in the remap, is it possible for LCNC to execute the tool change (or similar sequence with physical movement) even though the operator stopped at the preceding line?
- Thank you received: 7468
20 Oct 2021 13:21 #223668
Replied by tommylight on topic Stepping a program - bug or feature?
I wonder if it stops after adding F10 to each line ???
- spumco
20 Oct 2021 13:28 #223670
by spumco
It does not. I tried it both ways. Any movement line stops until cycle-start, step, or whatever the button equivalent is pressed. The movement line does not require an F-word. The F-word (modal feedrate) is carried through to the next line.
I've not tested every single non-movement G-word or M-word, but my stupid little "flash the flood light to check button function" is what triggered this whole thing. M8 does it, G4 dwells do it, M9, M7.
I didn't have the guts to try an M3/M4 just yet...
20 Oct 2021 14:15 #223673
Thank you, was just curious .
- spumco
20 Oct 2021 14:38 #223675
by spumco
I'm going to try it with an M3/M5 in the program tonight - will report back later.
Can anyone else think of a potentially dangerous modal command to test?
- anfänger
- Thank you received: 256
20 Oct 2021 14:47 #223676
by anfänger
Replied by anfänger on topic Stepping a program - bug or feature?
M64 or M65 could bring you into trouble depends on what you switch with them. What about user Mcodes?
- spumco
20 Oct 2021 14:56 #223678
by spumco
Good one - I'll try those too.
I'll connect an output to M64/M65 in my test HAL and add it to the "Single-block-roulette" file tonight.
We can pretend M64 turns on the part-loader robot automatic sequence. Wouldn't that be fun to have execute without being ready for it?
- spumco
21 Oct 2021 02:51 #223755
by spumco
Update after testing:
Feed hold and then stepping through a program only appears to stop at axis movement lines. All other modal g-code words I tested will be executed.
It's a little disconcerting watching the spindle turn on 10 lines down from where you stopped it and requested a single step/line.
I don't have a tool changer or my manual M6 set up, but M3/4/5, M7/8/9, and M64, M65 all executed automatically with a single step.
The other thing that made me anxious was that the active code line indicator (little arrow) in the program window stopped at the point where I did a feedhold, despite subsequent lines being executed. The indicator then jumped down through the program when it had finished all the 'test' code lines to the first motion line.
I know my test program(s) were pretty far-fetched (lots of M8/M9's), but I think it reasonable to single-block/step through an unfamiliar program to a tool change and expect the spindle & coolant to NOT turn on until you plan on it.
If anyone else can spare the time to test this with some user M-codes or other potentially dangerous conditions I'd appreciate it. I'm very new at LCNC and don't want to assume LCNC is 'broken' or that single-block needs to be treated with utmost caution until someone more experienced confirms my suspicions.
Thanks,
Ralph
Thanks,
Ralph
Time to create page: 0.132 seconds
