LinuxCNC on non-backdoored hardware - what are the options?
- Octoplex
- Thank you received: 4
I would like to install LinuxCNC on multiple machines for a secure project.
We cannot use backdoored CPUs. Therefore, all Intel and AMD processors post-2005 are unusable for our manufacturing project. This is on account of the chip-on-chip surveillance engines present in almost all post-2005 CPU hardware (IME on Intel / PSP on AMD).
Because of this problem, we have plans to design our CNC-router and robot-arm control systems based on PowerPC970 chips. We can repurpose these from G5 PowerMacs. I have now been tasked with researching different software we can use on these secure CPUs, rather than writing our own from scratch.
I like the look of LinuxCNC.
I understand that LinuxCNC runs using the RTAI (Realtime Application Interface) patch. I can see on the RTAI site that older versions of RTAI supported PowerPC. Does anyone here know what the latest version of RTAI to support PowerPC / secure CPUs was?
Is anyone here running LinuxCNC on secure hardware, or are most LinuxCNC systems based on these newer backdoored-chip architectures?
Alternatively, I'm also considering reverting to m68k processors, as they are also secure, and were supported by RTAI. We would prefer, however, to use the PowerPC970x series, as these are the fastest available chips currently available in volume (on the second-hand market) for those who wish to build a secure manufacturing system without surveillance backdoors.
Obviously, we could air-gap our manufacturing systems and just use the compromised post-2005 hardware, but we would like our manufacturing systems to be operable remotely.
I'd love to hear from anyone who has bulit a secure LinuxCNC system using PowerPC or m68k hardware. Thanks!
- spumco
- Thank you received: 905
puri.sm/products/librem-mini/
A quick internet search revealed a few other vendors as well. You may not be stuck with old hardware.
- Octoplex
Purism are working backwards to fix compromised hardware.
We'd like to begin secure.
To use a metaphor: We want to build a safe LinuxCNC-based 'swimming pool' for our engineers to 'swim in' as they work. Purism offer the (yet-to-be-reached) goal of muzzling the 'shark' (IME / PSP) in the water. But we'd prefer a pool which never had a 'shark' in to begin with
Hope this makes sense.
- Thank you received: 5329
- Octoplex
I will investigate this option.
- Thank you received: 7487
I am a highly paranoid computer user with a lifetime of professional experience, still i have over 10 PC's on 24h, all running Linux, and i am fully aware of the amount of data they send ....
So i do understand what you are trying to achieve, but using old hardware implies using old software, and that poses a security risk as they might not broadcast data but might get hacked into by using vulnerabilities inherent in them.
On the other side, a bit of effort usually proves fruitful by choosing new-ish software with lite GUI/DE and forcing it to work on older systems, did that a lot several years back, still have a HP thin client with Geode 1GHz processor running LinuxCNC 2.7 nicely.
Questions:
-are you designing new boards or using existing?
-by 68k you mean 68000 Motorola processors?
-how about using pre 2005 Xeon workstations?
Answers (maybe):
-search for Debian Dog LinuxCNC, over 200MB ISO ready for use, should run on pretty much anything from PIII@700MHz
-search for coolcnc iso, over 50MB ISO ready for use, should run on anything from PII@300MHz
-using new Debian with lite Desktop environment works on quite old systems, Core2 for sure works nicely
-having a go at installing RT kernel and LinuxCNC on Porteus Linux is also an option as that is still updated and maintained and is extremely lite and very low on resources.
- Thank you received: 4149
- rollfree
- Thank you received: 11
It works well. Whether with Mesa or with EtherCAT, for example.
And isn't it enough just to get rid of the possibility of communication to the world? Even if there is some coprocessor spying, the information will never leave the PC.
- Octoplex
We'd like to use existing boards.
Yes, they are non-backdoored and (later chips) are capable, but we'd prefer to use something more modern.
I'll look into this. Do you happen to know the best Intel-based industrial workstation from 2005? Or some idea of the reliable manufacturers who were producing off-the-shelf machines for this purpose around this time? It's hard to determine this through searches.
We're also looking at AMD options, since AMD did not backdoor their CPUs until several years after Intel. I have found a list here of non-backdoored AMD CPUs. Again, however, I am finding it difficult to determine precisely which manufacturers and workstations from this era are advisable to use for industrial applications.
Obviously, I can just build custom systems from these older, secure components. But, I wondered if anyone knew of any good off-the-shelf complete-workstations using these non-backdoored AMD CPUs?
Thanks again for everyone's help on this topic!
- Octoplex
And what about RPi4?
Sadly, this solution is also backdoored . We looked into the modern single-board options,like the RPi4, but there appears to be a problem with secure computing across the industry today. The only viable option seems to either air-gap a modern, backdoored, surveillance system CPU, or use a processor manufactured from 2005 or prior (Intel) or 2012 or prior (AMD).
Since we don't want to air-gap, or support surveillance-based CPU manufacturers, it looks like the way forward is to retrace the 'evolution' of computing to the point before CPUs were backdoored, and for us to choose a system that can be trusted.
