Warning not registered Parallel Port found
- mBender
- Thank you received: 15
20 Oct 2021 21:40 #223710
by mBender
Warning not registered Parallel Port found was created by mBender
Hi all,
I am pretty new to LinuxCNC but I like it a lot! I bought a second parallel Port card and all is working fine. The IOs start at 0x1100. However, when I start LinuxCNC I get the attached warning. I can“t find any information how to get rid of it. Any help is appreciated.
Mike
Mike
- Thank you received: 5321
20 Oct 2021 22:08 - 20 Oct 2021 22:09 #223712
Replied by PCW on topic Warning not registered Parallel Port found
What version of LinuxCNC?
Really that's an unimportant report that should just go
in the text log, not bug the user with a pop-up...
Last edit: 20 Oct 2021 22:09 by PCW.
- mBender
20 Oct 2021 23:30 #223720
by mBender
Replied by mBender on topic Warning not registered Parallel Port found
2.8.2.11 as in the header of the image
Time to create page: 0.098 seconds
