StepConf StepScale and Encoder Scaling not right, following error
21 Oct 2021 17:14 #223828 by Redneck92
Hey guys,
I´m back with just another problem I can´t seem to figure out.
I got my Step_Scale calculated with the tool in the StepConf Wizard.
When I Test the axis in open loop with the wizard, and tell it to move 5mm it only moves about 4,91mm.
So I recon the step scale must be wrong.
The X and Y axis I have 4mm pitch ballscrews.
The Ballscrew has a 34 tooth pulley and
the Nema 34 motor has a 26 tooth pulley
The Z axis has a 5mm pitch ballscrew.
Motors have 200 Steps per revolution and run on 2 times step multiplication eg. 400 steps per revolution.
I confirmed with the dial indicator that all the axis don´t have any backlash, they are as tight as can be.
Second problem I got is, when I run my machine in closed loop and jog it, I keep getting following error messages.
I think my encoder scaling is not right or my machine doesnt seem to like it.
Encoder PPM as stated on the box is 1000
I calculated as follows:
5mm pitch * (34/26 tooth) * 4000 counts / 5 =  5230.769 counts per millimeter
4mm pitch * (34/26 tooth) * 4000 counts / 4 = 5239.796 counts per millimeter
I´ll post my INI and my HAL file right below.
Woulkd be awesome if someone could help me with this or lead me on the right way.
Greeetings, Mike
HAL file:
loadrt [KINS]KINEMATICS
loadrt hostmot2
loadrt hm2_eth board_ip="10.10.10.10" config=" num_encoders=4 num_pwmgens=0 num_stepgens=4 sserial_port_0=0xxxxx"
loadrt pid names=pid.x,pid.y,pid.z,pid.s
setp hm2_7i96.0.watchdog.timeout_ns 5000000
setp hm2_7i96.0.dpll.01.timer-us -100
setp hm2_7i96.0.stepgen.timer-number 1
addf hm2_7i96.0.read          servo-thread
addf motion-command-handler   servo-thread
addf motion-controller        servo-thread
addf pid.x.do-pid-calcs       servo-thread
addf pid.y.do-pid-calcs       servo-thread
addf pid.z.do-pid-calcs       servo-thread
addf pid.s.do-pid-calcs       servo-thread
addf hm2_7i96.0.write         servo-thread
# external output signals
# external input signals
# --- BOTH-HOME-X ---
net both-home-x     <=  hm2_7i96.0.gpio.001.in
# --- BOTH-HOME-Y ---
net both-home-y     <=  hm2_7i96.0.gpio.002.in
# --- BOTH-HOME-Z ---
net both-home-z     <=  hm2_7i96.0.gpio.003.in
#  AXIS X JOINT 0
#//---Positionsrueckmeldung/ Inkrementalgeber---
setp hm2_7i96.0.encoder.00.counter-mode 0
setp hm2_7i96.0.encoder.00.filter 1
setp hm2_7i96.0.encoder.00.index-invert 0
setp hm2_7i96.0.encoder.00.index-mask 0
setp hm2_7i96.0.encoder.00.index-mask-invert 0
setp hm2_7i96.0.encoder.00.scale [JOINT_0]ENCODER_SCALE
setp   pid.x.Pgain     [JOINT_0]P
setp   pid.x.Igain     [JOINT_0]I
setp   pid.x.Dgain     [JOINT_0]D
setp   pid.x.bias      [JOINT_0]BIAS
setp   pid.x.FF0       [JOINT_0]FF0
setp   pid.x.FF1       [JOINT_0]FF1
setp   pid.x.FF2       [JOINT_0]FF2
setp   pid.x.deadband  [JOINT_0]DEADBAND
setp   pid.x.maxoutput [JOINT_0]MAX_OUTPUT
setp   pid.x.error-previous-target true
#setp   pid.x.maxerror 0.012700
net x-index-enable  <=> pid.x.index-enable
net x-enable        =>  pid.x.enable
net x-pos-cmd       =>  pid.x.command
net x-pos-fb        =>  pid.x.feedback
net x-output        <=  pid.x.output
# Step Gen signals/setup
setp   hm2_7i96.0.stepgen.00.dirsetup        [JOINT_0]DIRSETUP
setp   hm2_7i96.0.stepgen.00.dirhold         [JOINT_0]DIRHOLD
setp   hm2_7i96.0.stepgen.00.steplen         [JOINT_0]STEPLEN
setp   hm2_7i96.0.stepgen.00.stepspace       [JOINT_0]STEPSPACE
setp   hm2_7i96.0.stepgen.00.position-scale  [JOINT_0]STEP_SCALE
setp   hm2_7i96.0.stepgen.00.step_type        0
setp   hm2_7i96.0.stepgen.00.control-type     1
setp   hm2_7i96.0.stepgen.00.maxaccel         [JOINT_0]STEPGEN_MAXACCEL
setp   hm2_7i96.0.stepgen.00.maxvel           [JOINT_0]STEPGEN_MAXVEL
# ---closedloop stepper signals---
net x-pos-cmd    <= joint.0.motor-pos-cmd
net x-vel-cmd    <= joint.0.vel-cmd
net x-output     <= hm2_7i96.0.stepgen.00.velocity-cmd
net x-pos-fb     <= hm2_7i96.0.encoder.00.position
net x-pos-fb     => joint.0.motor-pos-fb
net x-enable     <= joint.0.amp-enable-out
net x-enable     => hm2_7i96.0.stepgen.00.enable
# ---setup home / limit switch signals---
net both-home-x     =>  joint.0.home-sw-in
net both-home-x     =>  joint.0.neg-lim-sw-in
net both-home-x     =>  joint.0.pos-lim-sw-in
#  AXIS Y JOINT 1
setp hm2_7i96.0.encoder.01.counter-mode 0
setp hm2_7i96.0.encoder.01.filter 1
setp hm2_7i96.0.encoder.01.index-invert 0
setp hm2_7i96.0.encoder.01.index-mask 0
setp hm2_7i96.0.encoder.01.index-mask-invert 0
setp hm2_7i96.0.encoder.01.scale [JOINT_1]ENCODER_SCALE
setp   pid.y.Pgain     [JOINT_1]P
setp   pid.y.Igain     [JOINT_1]I
setp   pid.y.Dgain     [JOINT_1]D
setp   pid.y.bias      [JOINT_1]BIAS
setp   pid.y.FF0       [JOINT_1]FF0
setp   pid.y.FF1       [JOINT_1]FF1
setp   pid.y.FF2       [JOINT_1]FF2
setp   pid.y.deadband  [JOINT_1]DEADBAND
setp   pid.y.maxoutput [JOINT_1]MAX_OUTPUT
setp   pid.y.error-previous-target true
setp   pid.y.maxerror 0.012700
net y-index-enable  <=> pid.y.index-enable
net y-enable        =>  pid.y.enable
net y-pos-cmd       =>  pid.y.command
net y-pos-fb        =>  pid.y.feedback
net y-output        <=  pid.y.output
setp   hm2_7i96.0.stepgen.01.dirsetup        [JOINT_1]DIRSETUP
setp   hm2_7i96.0.stepgen.01.dirhold         [JOINT_1]DIRHOLD
setp   hm2_7i96.0.stepgen.01.steplen         [JOINT_1]STEPLEN
setp   hm2_7i96.0.stepgen.01.stepspace       [JOINT_1]STEPSPACE
setp   hm2_7i96.0.stepgen.01.position-scale  [JOINT_1]STEP_SCALE
setp   hm2_7i96.0.stepgen.01.step_type        0
setp   hm2_7i96.0.stepgen.01.control-type     1
setp   hm2_7i96.0.stepgen.01.maxaccel         [JOINT_1]STEPGEN_MAXACCEL
setp   hm2_7i96.0.stepgen.01.maxvel           [JOINT_1]STEPGEN_MAXVEL
net y-pos-cmd    <= joint.1.motor-pos-cmd
net y-vel-cmd    <= joint.1.vel-cmd
net y-output     <= hm2_7i96.0.stepgen.01.velocity-cmd
net y-pos-fb     <= hm2_7i96.0.encoder.01.position
net y-pos-fb     => joint.1.motor-pos-fb
net y-enable     <= joint.1.amp-enable-out
net y-enable     => hm2_7i96.0.stepgen.01.enable
net both-home-y     =>  joint.1.home-sw-in
net both-home-y     =>  joint.1.neg-lim-sw-in
net both-home-y     =>  joint.1.pos-lim-sw-in
#  AXIS Z JOINT 2
setp hm2_7i96.0.encoder.02.counter-mode 0
setp hm2_7i96.0.encoder.02.filter 1
setp hm2_7i96.0.encoder.02.index-invert 0
setp hm2_7i96.0.encoder.02.index-mask 0
setp hm2_7i96.0.encoder.02.index-mask-invert 0
setp hm2_7i96.0.encoder.02.scale [JOINT_2]ENCODER_SCALE
setp   pid.z.Pgain     [JOINT_2]P
setp   pid.z.Igain     [JOINT_2]I
setp   pid.z.Dgain     [JOINT_2]D
setp   pid.z.bias      [JOINT_2]BIAS
setp   pid.z.FF0       [JOINT_2]FF0
setp   pid.z.FF1       [JOINT_2]FF1
setp   pid.z.FF2       [JOINT_2]FF2
setp   pid.z.deadband  [JOINT_2]DEADBAND
setp   pid.z.maxoutput [JOINT_2]MAX_OUTPUT
setp   pid.z.error-previous-target true
setp   pid.z.maxerror 0.012700
net z-index-enable  <=> pid.z.index-enable
net z-enable        =>  pid.z.enable
net z-pos-cmd       =>  pid.z.command
net z-pos-fb        =>  pid.z.feedback
net z-output        <=  pid.z.output
setp   hm2_7i96.0.stepgen.02.dirsetup        [JOINT_2]DIRSETUP
setp   hm2_7i96.0.stepgen.02.dirhold         [JOINT_2]DIRHOLD
setp   hm2_7i96.0.stepgen.02.steplen         [JOINT_2]STEPLEN
setp   hm2_7i96.0.stepgen.02.stepspace       [JOINT_2]STEPSPACE
setp   hm2_7i96.0.stepgen.02.position-scale  [JOINT_2]STEP_SCALE
setp   hm2_7i96.0.stepgen.02.step_type        0
setp   hm2_7i96.0.stepgen.02.control-type     1
setp   hm2_7i96.0.stepgen.02.maxaccel         [JOINT_2]STEPGEN_MAXACCEL
setp   hm2_7i96.0.stepgen.02.maxvel           [JOINT_2]STEPGEN_MAXVEL
net z-pos-cmd    <= joint.2.motor-pos-cmd
net z-vel-cmd    <= joint.2.vel-cmd
net z-output     <= hm2_7i96.0.stepgen.02.velocity-cmd
net z-pos-fb     <= hm2_7i96.0.encoder.02.position
net z-pos-fb     => joint.2.motor-pos-fb
net z-enable     <= joint.2.amp-enable-out
net z-enable     => hm2_7i96.0.stepgen.02.enable
net both-home-z     =>  joint.2.home-sw-in
net both-home-z     =>  joint.2.neg-lim-sw-in
net both-home-z     =>  joint.2.pos-lim-sw-in
# connect miscellaneous signals
#  ---HALUI signals---
net axis-select-x  halui.axis.x.select
net jog-x-pos      halui.axis.x.plus
net jog-x-neg      halui.axis.x.minus
net jog-x-analog   halui.axis.x.analog
net x-is-homed     halui.joint.0.is-homed
net axis-select-y  halui.axis.y.select
net jog-y-pos      halui.axis.y.plus
net jog-y-neg      halui.axis.y.minus
net jog-y-analog   halui.axis.y.analog
net y-is-homed     halui.joint.1.is-homed
net axis-select-z  halui.axis.z.select
net jog-z-pos      halui.axis.z.plus
net jog-z-neg      halui.axis.z.minus
net jog-z-analog   halui.axis.z.analog
net z-is-homed     halui.joint.2.is-homed
net jog-selected-pos      halui.axis.selected.plus
net jog-selected-neg      halui.axis.selected.minus
net spindle-manual-cw     halui.spindle.0.forward
net spindle-manual-ccw    halui.spindle.0.reverse
net spindle-manual-stop   halui.spindle.0.stop
net machine-is-on         halui.machine.is-on
net jog-speed             halui.axis.jog-speed
net MDI-mode              halui.mode.is-mdi
#  ---coolant signals---
net coolant-mist      <=  iocontrol.0.coolant-mist
net coolant-flood     <=  iocontrol.0.coolant-flood
#  ---probe signal---
net probe-in     =>  motion.probe-input
#  ---motion control signals---
net in-position               <=  motion.in-position
net machine-is-enabled        <=  motion.motion-enabled
#  ---digital in / out signals---
#  ---estop signals---
net estop-out     <=  iocontrol.0.user-enable-out
net estop-out     =>  iocontrol.0.emc-enable-in
#  ---manual tool change signals---
net tool-change-request     iocontrol.0.tool-change       =>  hal_manualtoolchange.change
net tool-change-confirmed   iocontrol.0.tool-changed      <=  hal_manualtoolchange.changed
net tool-number             iocontrol.0.tool-prep-number  =>  hal_manualtoolchange.number
net tool-prepare-loopback   iocontrol.0.tool-prepare      =>  iocontrol.0.tool-prepared
INI File:
HOSTMOT2]
DRIVER =     hm2_eth
BOARD =     7i96
Config =    "num_encoders=4 num_pwmgens=0 num_stepgens=4 sserial_port_0=0xxxxx"
[EMC]
MACHINE = RedneckCNC
DEBUG = 0
VERSION = 1.1
[DISPLAY]
DISPLAY =                     axis
POSITION_OFFSET =             RELATIVE
POSITION_FEEDBACK =         ACTUAL
MAX_FEED_OVERRIDE =         2.000000
MAX_SPINDLE_OVERRIDE =         2.000000
MIN_SPINDLE_OVERRIDE =         0.500000
INTRO_TIME =                 5
PROGRAM_PREFIX =             /home/redneck/linuxcnc/nc_files
INCREMENTS =                 5mm 1mm .5mm .1mm .05mm .01mm .005mm
DEFAULT_LINEAR_VELOCITY =     6.000000
MAX_LINEAR_VELOCITY =         83.333333
MIN_LINEAR_VELOCITY =         0.500000
DEFAULT_ANGULAR_VELOCITY =     12.000000
MAX_ANGULAR_VELOCITY =         180.000000
MIN_ANGULAR_VELOCITY =         1.666667
EDITOR =                     gedit
GEOMETRY =                     xyz
[FILTER]
PROGRAM_EXTENSION =         .png,.gif,.jpg Greyscale Depth Image
PROGRAM_EXTENSION =         .py Python Script
png = image-to-gcode
gif = image-to-gcode
jpg = image-to-gcode
py = python
[TASK]
TASK =             milltask
CYCLE_TIME =     0.010
[RS274NGC]
PARAMETER_FILE = linuxcnc.var
[EMCMOT]
EMCMOT =             motmod
COMM_TIMEOUT =         1.0
SERVO_PERIOD =         1000000
[HMOT]
# **** This is for info only ****
CARD0=hm2_7i96.0
[HAL]
HALUI =             halui
HALFILE =             RedneckCNC.hal
HALFILE =             custom.hal
POSTGUI_HALFILE =     postgui_call_list.hal
SHUTDOWN =             shutdown.hal
[HALUI]
[KINS]
JOINTS = 3
KINEMATICS = trivkins coordinates=XYZ
[TRAJ]
COORDINATES =                  XYZ
LINEAR_UNITS =                 mm
ANGULAR_UNITS =             degree
DEFAULT_LINEAR_VELOCITY =     16.67
MAX_LINEAR_VELOCITY =         166.67
[EMCIO]
EMCIO =         io
CYCLE_TIME =     0.100
TOOL_TABLE =     tool.tbl
[AXIS_X]
MAX_VELOCITY =         83.3333333333
MAX_ACCELERATION =     500.0
MIN_LIMIT =        -5.0
MAX_LIMIT =         370.0
[JOINT_0]
TYPE =                 LINEAR
HOME =                 0.0
ENCODER_SCALE =     5230.769
FERROR =             10.0
MIN_FERROR =        1.0
STEPGEN_MAXVEL =     130.769
STEPGEN_MAXACCEL =     500
P =             20
I =             0
D =             0
FF0 =             0
FF1 =             1.6
FF2 =             0.01
BIAS =             0
DEADBAND =         0.005
MAX_OUTPUT =     0
# these are in nanoseconds
DIRSETUP   =     10000
DIRHOLD    =     10000
STEPLEN    =     5000
STEPSPACE  =     5000
STEP_SCALE =     130.7692
MIN_LIMIT =     -5.0
MAX_LIMIT =     370
HOME_OFFSET = -5.000000
HOME_SEARCH_VEL = -6.500000
HOME_LATCH_VEL = -0.833333
HOME_FINAL_VEL = 8.333333
HOME_USE_INDEX = NO
HOME_IGNORE_LIMITS = YES
HOME_SEQUENCE = 1
[AXIS_Y]
MIN_LIMIT =         -5.0
MAX_LIMIT =         250
[JOINT_1]
TYPE =                 LINEAR
HOME =                 0.0
FERROR =             10.0
MIN_FERROR =         1.0
P =             20
I =             0
D =             0
FF0 =             0
FF1 =             1.6
FF2 =             0.01
BIAS =             0
DEADBAND =         0.005
MAX_OUTPUT =     0
DIRSETUP   =     10000
DIRHOLD    =     10000
STEPLEN    =    5000
STEPSPACE  =    5000
MIN_LIMIT =     -5.0
MAX_LIMIT =     250
HOME_USE_INDEX = NO
HOME_SEQUENCE = 0
[AXIS_Z]
MAX_VELOCITY =         50.0
MIN_LIMIT =         -300.0
MAX_LIMIT =         5.00
[JOINT_2]
TYPE =                     LINEAR
HOME =                     0.0
FERROR =                 10.0
MIN_FERROR =             1.0
MAX_VELOCITY =             50.0
STEPGEN_MAXVEL =         104.615
STEPGEN_MAXACCEL =         350
P =             50
I =                0
D =             0
FF0 =             0
FF1 =             1.9
FF2 =             0.001
BIAS =             0
DEADBAND =         0.005
MAX_OUTPUT =     0
DIRSETUP   =     10000
DIRHOLD    =     10000
STEPLEN    =     5000
STEPSPACE  =     5000
STEP_SCALE =    104.6154
MIN_LIMIT =     -300.0
MAX_LIMIT =     5.00
HOME_OFFSET =    5.0
HOME_SEARCH_VEL = 6.500000
HOME_LATCH_VEL = 0.833333
HOME_USE_INDEX = NO
HOME_SEQUENCE = 0
[SPINDLE_0]
P = 0
I = 0
D = 0
FF0 = 1
FF1 = 0
FF2 = 0
BIAS = 0
DEADBAND = 0
MAX_OUTPUT = 2000
22 Oct 2021 00:23 #223858 by PCW
To get a step.dir system working with encoder feedback you need to
first get the scaling of the step/dir and encoders identical.
Also FF1 should always be 1.000. For tuning, the following error limits
need to be widened to allow for large errors with initial tuning
22 Oct 2021 06:18 #223882 by Redneck92
Thank you on the tip with the ff1 and the following error.
Do you have any tips how I can accurately figure out the stepscale and encoder scale counts?
22 Oct 2021 16:05 #223928 by PCW
You should be able to use your dial indicator to verify the encoder
position even in open loop mode by using halmeter to read the encoder
position pin value.
The following user(s) said Thank You: Redneck92
22 Oct 2021 17:14 - 22 Oct 2021 17:15 #223932 by Redneck92
I did as you said and got X and Y axis working perfectly now. Even finished to tune them with halscope and everything.
But Z axis on the other hand is giving me a headache.
I did the same procedures on Z and it will not work.
I started in open loop again, let the Step_Conf calculator do its thing and tested the axis.
When I told it to move + - 2mm it falls about 0.05mm short.
It only moves 3.95mm.
When I told it to move + - 5mm it did the exact same thing.
It moved 0.05mm to short.
I then manually raised the Step_Scale until it moved exactly what I wanted it to.
So far so good.
Then I went and put this Step_Scale and used it in Axis.
When I tell it to move Z -1 it exactly moves 1mm.
Then I tell it to move Z -5 and then it only moves 4.95mm again.
When I then tell it to move Z -7 it only moves to about 6.65mm.
But when I tell it to move to Z0 again, it moves exactly to the 0 starting point.
It´s like there is some kind of cascading error or something.
I can´t get my head around this.
Do you have more sugestions for me?
Thank you very much in advance.
Last edit: 22 Oct 2021 17:15 by Redneck92.
22 Oct 2021 17:57 #223936 by PCW
is Z open or closed loop?
If closed loop what does the encoder position show vs the commanded position?
22 Oct 2021 18:15 - 22 Oct 2021 18:15 #223937 by Redneck92
Z works in closed loop aswell in Axis.
How can I See the encoder Position and the commanded Position?
Can I check this with the hal Meter?
Last edit: 22 Oct 2021 18:15 by Redneck92.
22 Oct 2021 18:24 #223938 by PCW
if its closed loop (and Z is mapped to joint 2):
would be the commanded joint position, and:
would be connected to the encoder position
You can view these with halscope, halmeter or halshow
22 Oct 2021 18:28 #223939 by Redneck92
Thank you very much, I will check this tomorrow and report back
23 Oct 2021 10:06 #223977 by Redneck92
So I checked what you suggested yesterday.
I tried a more ridgid idicator stand and another dial indicator.
The error is actuall not cascading.
On every value it just moves 0.03mm to short.
Joint.2.motor-pos-cmd  is 38.19773
joint.2.motor-pos-fb     is 38.1961
So it seems to be 0.0011mm off as I See.
But this would not explain the 0.03mm that are missing.
I used the Step_Scale and Encoder_Scale values that were calculated from the Pncconf Programm.
Step_Scale 104.615
Encoder_Scale 1046.154
Could it be that the pitch on the Z ballscrew is off?
What Do you think?
Time to create page: 0.287 seconds
