stepgen parameters syntax in 2.8 with Mesa 7i96
- PaulQUE
26 Oct 2021 07:54 - 26 Oct 2021 07:56 #224343
by PaulQUE
stepgen parameters syntax in 2.8 with Mesa 7i96 was created by PaulQUE
hi, i'm struggling to get my tool changer component working, and I think I have it narrowed down to these to lines :
net astep <= stepgen.3.step
net adir <= stepgen.3.dir
My axis is is step up as "s" and not "a" on stepgen 2 ( generated by the pncconf wizard) so my signals are sstep & sdir (is that even right, or is the componenent looking specifically for an A axis? ), but I can seem to find if "stepgen.X.step" and "stepgen.X.dir", are still the right parameters under linuxcnc 2.8?
thank you all for your help
Last edit: 26 Oct 2021 07:56 by PaulQUE.
- Thank you received: 5320
26 Oct 2021 22:18 #224433
Replied by PCW on topic stepgen parameters syntax in 2.8 with Mesa 7i96
Those pins do not exist in a Mesa configuration,
you can just delete them
The following user(s) said Thank You: PaulQUE
Time to create page: 0.225 seconds
