Error after using home all
- yi2580
- Thank you received: 3
27 Oct 2021 05:55 #224473
by yi2580
Error after using home all was created by yi2580
Hello, after using home all in qtvcp, I will report this error by clicking return to zero again. It seems that I have encountered this error before, but I didn't pay attention at that time. I always use single axis return to zero. The error is "cannot home while shared home switch is closed J = 2". I don't know how to solve it. I hope someone can help me.
thank you
thank you
- Thank you received: 7468
27 Oct 2021 10:43 #224489
Replied by tommylight on topic Error after using home all
Are you using shared switches?
Adding a bit of offset to home_ofset usually takes care of that as it backs off of the switches, so 2 or 3mm are more that enough.
- yi2580
29 Oct 2021 01:12 #224621
by yi2580
Replied by yi2580 on topic Error after using home all
I am now using the virtual machine to write the interface. After I write the interface on the virtual machine, I will transplant it to the machine for testing
Time to create page: 0.087 seconds
