LinuxCNC with BRX do more plc
- abhi007
28 Oct 2021 06:02 #224551
by abhi007
LinuxCNC with BRX do more plc was created by abhi007
hi there,
I'm thinking to upgrade one of my old milling machine into CNC. I'm thinking to use PLC as a hardware connection and linuxCNC for make things easy. So, is it possible to use BRX do more plc with LinuxCNC ?????
- Thank you received: 1472
03 Nov 2021 15:33 #225111
Replied by Todd Zuercher on topic LinuxCNC with BRX do more plc
I doubt there is a supported way to have realtime communication between the BRX plc and Linuxcnc, therefore limiting its usefulness. It would make more sense to spend the money on realtime IO such as a Mesa card and then using the built in PLC programming in Linuxcnc.
Time to create page: 0.073 seconds
