Making mill linuxcnc some questions.
- Madkite
29 Oct 2021 07:24 #224631
by Madkite
Making mill linuxcnc some questions. was created by Madkite
Hi helpful people.
I am looking to convert my cnc mill to linuxcnc.
it's a basic setup. 3 axis, 3 home switches, steppers and DC brush spindle.
There's a couple of things I'm not sure about.
I have an index signal from the spindel and would like it to have feedback compensation. As it's it's old DC brush motor it tends to drop a lot of RPM and so you have to guess how much over to set the rpm. Especially at slower speeds.
Can I use just an index input to get the rpm? As I see all the documents on this referring to this on lathes so has a disk with lots of slots as well. I have a lathe project so that's of interest but not needed for the mill.
if I can get the rpm from just the index can I have linux cnc adjust the output to maintain the rpm under load? So when it slows when for example drilling. It will turn up the power to compensate?
Second is, can I install a second parallel port to connect an mpg? Or what do you use to connect an mpg?
Thanks.
Thanks.
- BigJohnT
- Thank you received: 994
29 Oct 2021 21:26 #224678
by BigJohnT
Replied by BigJohnT on topic Making mill linuxcnc some questions.
I'm pretty sure you can get a speed estimate with just an index pulse, can you mount an encoder on the spindle shaft?
LinuxCNC supports two parallel ports but not all PCI parallel ports work... you might consider a Mesa 7i96 which is controlled over the motherboard's ethernet port and supports 5 axis plus spindle. It works with less than ideal latency, software stepping via the parallel port requires pretty low latency.
JT
JT
- Madkite
30 Oct 2021 07:46 #224705
by Madkite
Replied by Madkite on topic Making mill linuxcnc some questions.
That's interesting.
What kind of puls frequency can you get from the PP. I'm going to use that at first as it's the cheep option to test everything.
Also what's considered high latency on the PP?
Thanks.
Thanks.
- Thank you received: 7468
30 Oct 2021 11:46 #224716
Replied by tommylight on topic Making mill linuxcnc some questions.
15 to 20KHz is doable on parallel port, with some luck in finding a good PC and RTAI kernel a bit more, but do not count on it.
Time to create page: 0.090 seconds
