Abnormal sound of machine tool
5 years 1 day ago - 5 years 1 day ago #224774 by wang
This is my CNC machine tool. I use it for laser processing. For the XY axis, I use Kollmorgen drive and Kollmorgen linear motor. For linuxcnc, I use version 2.9 and ethercat communication. But it occasionally produces abnormal mechanical noises like the ones in the video. When I restart the software, there is a high probability that the abnormal noises will disappear. I found the result " forum.linuxcnc.org/ethercat/43855-delta-...ication-issue#222451 " in the forum, and I followed the explanation inside. I changed refClockSyncCycles="-1". I'm not sure if it works, but doing so often results in Estop in operation. So I had to set refClockSyncCycles="5", this is my initial configuration. At the same time, I also checked the following configuration and there is no problem
-0x60C2:01 = 0x01 (interpolation time period 1ms)
-0x60C2:02 = 0xFD (interpoltatin time index 253)
Who can help me solve the problem of abnormal noise? Thank you very much
Last edit: 5 years 1 day ago by wang.
5 years 1 day ago #224781 by tommylight
Supposing it does not have belts, so do a hal scope of joint.N.motor-fb when that sound is present.
What type of feedback?
Does sound like encoder missing counts occasionally... so does the machine vibrate with those sounds ?
5 years 1 day ago #224821 by wang
Replied by wang on topic Abnormal sound of machine tool
I use a linear motor without a timing belt. I think the machine tool moves smoothly when abnormal noise occurs. So I think there is a problem with the ethercat connection, because this situation will disappear when I restart the software, usually this situation occurs in the morning when the machine is turned on. The feedback uses an incremental encoder.
I use Google Translate, if there is a deviation in the translation, I am very sorry
  • marke
  • New Member
  • New Member
5 years 1 day ago #224827 by marke
Replied by marke on topic Abnormal sound of machine tool
I think you should find out the cause of the noise and then find a solution to the noise.
4 years 10 months ago #228486 by wang
What should you do if the encoder occasionally loses counts? What should i do?
4 years 10 months ago #228490 by PCW
Replied by PCW on topic Abnormal sound of machine tool
Have you checked the host PCs latency?
Thumps and bangs can be latency related...
Time to create page: 0.395 seconds
