Abnormal sound of machine tool
4 years 10 months ago #228636 by 0x2102
As PCW asked, what is the latency on your system?
I had some strange noise on my testbench setup, when I used a PC with latency issues. Since I am using a PID for my test axis, I could see it in Halscope pid.x.error.
4 years 10 months ago #228666 by wang
Replied by wang on topic Abnormal sound of machine tool
This is the result of my delayed test. Do you think there will be a problem?
4 years 10 months ago - 4 years 10 months ago #228725 by 0x2102
Try this test: (maybe for 30 minutes or 1 hour)
forum.linuxcnc.org/18-computer/39370-scr...-of-computer-latency
Download the script and run with sudo
forum.linuxcnc.org/media/kunena/attachme...09-30_2020-10-02.zip
The default latency test is too simple.
Also, download and install "ethtool" with sudo apt install ethtool and run
sudo ethtool -c "your nic card here"
Everything should be set to 0, if not you will introduce delay.
use this to change the settings:
sudo ethtool -C "your nic card here" rx-usecs 0
sudo ethtool -C "your nic card here" tx-usecs 0
as an example.
Last edit: 4 years 10 months ago by 0x2102.
Time to create page: 0.198 seconds
