Inkscape closes when trying to save a file
  • Aldenflorio
  • Aldenflorio's Avatar Topic Author
  • Platinum Member
  • Platinum Member
31 Oct 2021 19:48 #224788 by Aldenflorio
Inkscape closes when trying to save a file was created by Aldenflorio
Just what the title says. I go to save as, press save as and it just closes.
31 Oct 2021 21:16 #224800 by d2inventory
Replied by d2inventory on topic Inkscape closes when trying to save a file
start from command line and see if you get more info there
  • Moderator
  • Moderator
31 Oct 2021 21:48 #224808 by tommylight
Replied by tommylight on topic Inkscape closes when trying to save a file
Linux or Windoze?
If Linux, most probably you are trying to save to a folder with no write permissions.
  • Aldenflorio
  • Platinum Member
  • Platinum Member
01 Nov 2021 16:28 #224892 by Aldenflorio
Replied by Aldenflorio on topic Inkscape closes when trying to save a file
Okay so I ran it through terminal and all things are good. It aves perfectly fine and all. It seems that the shortcut has an issue though. Any way to fix that?
01 Nov 2021 19:18 #224906 by d2inventory
You could try to fiddle with it. The shortcut file is:
/usr/share/applications/inkscape.dektop
You need root right to edit it. There is a line that should be:
Exec=inkscape %F
You could change this to call a script of yours to launch inkscape and get debug messages
Time to create page: 0.076 seconds
