HAL Memory Limitations
- tom.eagan@integrisgp.com
02 Nov 2021 21:32 #225042
by tom.eagan@integrisgp.com
HAL Memory Limitations was created by tom.eagan@integrisgp.com
Hello -
I've been developing a User Interface using axis/pyvcp, and have run out of HAL memory. This has happened twice. After the first time I depopulated some of it so I could continue developing other parts of it, hoping to consolidate later, but then I hit the memory limitation again.
I've seen other comments on this same topic... Is there a version of LinuxCNC that expands this limitation? Or is there something else I could do to expand it? I'm currently using v 2.8.2.
Note: This is a commercial development project, using LinuxCNC with a custom front end (although still using parts of Axis), so I don't want to do anything that would limit marketability due to licensing considerations.
Thanks,
Tom Eagan
Thanks,
Tom Eagan
- bevins
- Thank you received: 338
02 Nov 2021 21:43 - 02 Nov 2021 21:45 #225043
by bevins
Replied by bevins on topic HAL Memory Limitations
Are you using mesa cards? IF so, try turning off any unused stepgens and or encoders etc.... That should get you some more pins.
Turn of any components not needed and last resort change HAL_size in src/hal/hal_priv.h and recompile.
Last edit: 02 Nov 2021 21:45 by bevins.
- Thank you received: 7468
02 Nov 2021 21:52 #225045
Replied by tommylight on topic HAL Memory Limitations
Can not help with memory stuff as i am far behind in some aspects of LinuxCNC ....
But, i like this:
engineering.integrisgp.com/wp-content/up...10/Engineer-It-2.jpg
So now to answer your question with a totally unrelated question:
Do you have any remote job that i could fill?
But, i like this:
- BigJohnT
- Thank you received: 994
02 Nov 2021 22:05 #225048
by BigJohnT
Replied by BigJohnT on topic HAL Memory Limitations
You can increase hal memory... Jeff explains how in this email.
sourceforge.net/p/emc/mailman/emc-users/...nth=201006&viewday=3
JT
JT
- Thank you received: 4652
03 Nov 2021 00:15 - 03 Nov 2021 00:17 #225057
Replied by andypugh on topic HAL Memory Limitations
2.9 (development branch) has a pull request outstanding to increase HAL memory:
github.com/LinuxCNC/linuxcnc/pull/1171
But I already increased it earlier this year. (that change is already in 2.8, though)
Last edit: 03 Nov 2021 00:17 by andypugh.
- Thank you received: 2175
03 Nov 2021 08:22 #225079
Replied by cmorley on topic HAL Memory Limitations
sounds like a very complicated pyvcp - how many pins does it have?
My bet is you don't actually need these pins - other then with pyvcp that is not only way to control them.
Have you looked at gladevcp or qtvcp? They are more suited to building complicated screens - and only use pins when you actually need them, but you probably need to learn python programming a bit.
30 Nov 2021 20:09 #228067
Replied by tom.eagan@integrisgp.com on topic HAL Memory Limitations
Yes, it is a complicated vcp, and I'm sure there are better ways... but I'm trying for a "quick" prototype, and pycvp seemed like an easier solution than gladevcp or qtvcp, and I'm trying to avoid getting too deep in learning new things. I hadn't expected a memory allocation issue, however, I did fix my original problem by downloading, changing HAL_SIZE, and recompiling.
Thanks to all for your help.
(and to tommylight, can't hurt to apply
30 Nov 2021 20:14 #228068
...and I might offer a suggestion for the developer community, if you're monitoring this: How about adding HAL memory size as an INI setting rather than a #define in the code?
30 Nov 2021 22:33 #228080
Could it be dynamically allocated? Probably....
Because it is statically allocated, so would still need to be set at least as large as the INI setting. (ie, the INI could only ever reduce it from the #define value)...and I might offer a suggestion for the developer community, if you're monitoring this: How about adding HAL memory size as an INI setting rather than a #define in the code?
Time to create page: 0.162 seconds
