problem using [FILTER} to run a bash script
- ericg
- Thank you received: 10
05 Nov 2021 23:16 #225446
by ericg
problem using [FILTER} to run a bash script was created by ericg
Hi, I wrote a simple 2 line bash script to modify a Lightburn generated .gc file to run on LCNC, the script works fine from the command line.
my [FILTER] section includes ..
[FILTER]
PROGRAM_EXTENSION = .ngc,.gc Bash Script
gc = RunSED
I checked permissions etc and see nothing wrong, I tried using the .sh extension but still same result which is an error message saying "can't open /tmp/tmpxxxx/filename.gc" and also "file ended with no percent sign"
when I checked the tmpxxx file it was empty.
Other files such as a jpg works OK with image-to-gcode and I placed my RunSED file in the same place with the same permissions.
I assume LCNC is trying to place a copy of the original file into a tmp location to work on it but that it cannot seem to copy it properly.
Any suggestions would be appreciated
Eric
[FILTER]
gc = RunSED
Eric
- Thank you received: 7488
07 Nov 2021 22:27 #225595
You should attach the ini file here so we can have a look, pretty rusty since i last used this option for my needs.
Replied by tommylight on topic problem using [FILTER} to run a bash script
If that is exactly how you have it in the ini file, "bash script" can not be there, but i guess this is the forum editor messing up formatting.PROGRAM_EXTENSION = .ngc,.gc Bash Script
gc = RunSED
07 Nov 2021 23:55 #225603
Replied by andypugh on topic problem using [FILTER} to run a bash script
Does the bash script start with the correct "#! ...." ?
- ericg
08 Nov 2021 01:35 #225617
by ericg
Replied by ericg on topic problem using [FILTER} to run a bash script
Thanks for the response's guys, yes, the bash script does have the correct shebang and I put 'Bash Script' in following the python script example, I'll try it without "Bash Script"I have attached the .ini file and my executable bash script, (I put .txt extension on just so it would attach without error, that should be removed)
Eric
Eric
- Thank you received: 2181
08 Nov 2021 04:34 #225624
Replied by cmorley on topic problem using [FILTER} to run a bash script
What screen are you using?
- ericg
08 Nov 2021 06:40 #225629
by ericg
axis
08 Nov 2021 06:51 #225631
Here is the relevant code in axis. maybe that helps.
Looks like error checking/printing is sparse.
progress_re = re.compile("^FILTER_PROGRESS=(\\d*)$")
def filter_program(program_filter, infilename, outfilename):
import subprocess
outfile = open(outfilename, "w")
infilename_q = infilename.replace("'", "'\\''")
env = dict(os.environ)
env['AXIS_PROGRESS_BAR'] = '1'
p = subprocess.Popen(["sh", "-c", "%s '%s'" % (program_filter, infilename_q)],
stdin=subprocess.PIPE,
stdout=outfile,
stderr=subprocess.PIPE,
env=env)
p.stdin.close() # No input for you
progress = Progress(1, 100)
progress.set_text(_("Filtering..."))
stderr_text = []
try:
while p.poll() is None: # XXX add checking for abort
t.update()
r,w,x = select.select([p.stderr], [], [], 0.100)
if r:
stderr_line = p.stderr.readline()
m = progress_re.match(stderr_line)
if m:
progress.update(int(m.group(1)), 1)
else:
stderr_text.append(stderr_line)
sys.stderr.write(stderr_line)
# .. might be something left on stderr
for line in p.stderr:
m = progress_re.match(line)
if not m:
stderr_text.append(line)
sys.stderr.write(line)
return p.returncode, "".join(stderr_text)
finally:
progress.done()
def get_filter(filename):
ext = os.path.splitext(filename)[1]
if ext:
return inifile.find("FILTER", ext[1:])
else:
return None
- ericg
08 Nov 2021 07:02 #225632
by ericg
Thanks, but I'm no programmer so it doesn't help me, perhaps someone more knowledgeable can use it but for now if it's an issue within LCNC then I will just have to live with running the script manually from the command line,
At least I know it's not me.
Eric
Eric
08 Nov 2021 08:43 - 08 Nov 2021 08:44 #225639
Try:
PROGRAM_EXTENSION = .ngc Gcode
PROGRAM_EXTENSION = .gc Bash Script
gc = sh
gc = sh
Last edit: 08 Nov 2021 08:44 by cmorley.
- ericg
08 Nov 2021 10:14 #225655
by ericg
Just tried that and the sh command tried to interpret the file as a shell script and consequently every line failed, but it did at least read the file, I tried renaming my script as RunSED.sh but that was no help either.
Thanks for the thought.
