Linuxcnc simulatior
08 Nov 2021 23:13 - 08 Nov 2021 23:14 #225730 by Jmh474
Linuxcnc simulatior was created by Jmh474
Sorry if this has been posted before and if it's in the wrong place, iv found some information but not what I want am answer to.
I'm hoping it's possible to run a linuxcnc simulator,
just so I can start working on hal stuff and explor the software more.
My main concern is my cnc will be running off a parallel port but the laptop I plan on using doesn't have a parallel port, is it possible to make linuxcnc think there is a parallel port, and I'm going to be using 2 x parallel ports.
Then would it be OK to transfer the hal file to the actual file to the PC I'll be using?
Also is it possible to run this in virtual machine or would I have to dual boot into a Linux os?
Last edit: 08 Nov 2021 23:14 by Jmh474.
  • Moderator
  • Moderator
08 Nov 2021 23:22 #225731 by tommylight
Replied by tommylight on topic Linuxcnc simulatior
You can run simulations and use everything regarding Linux and LinuxCNC by booting from a USB stick without installing anything, you can even run machines from a USB if you already have a saved config.
So there is no need for dual boot or virtual machine, just beware that you will have to save you stuff on the hard drive or another USB, or even better make another partition on that same USB AFTER burning the ISO image.
The following user(s) said Thank You: Jmh474
08 Nov 2021 23:25 #225732 by Jmh474
Replied by Jmh474 on topic Linuxcnc simulatior
Thanks for the quick response
I'll have a look
  • Moderator
  • Moderator
08 Nov 2021 23:39 #225734 by tommylight
You are welcomed, always.
Time to create page: 0.401 seconds
